Wiring Help
Discussion in 'XJ Technical Chat' started by chopper716, Apr 3, 2009.
  1. chopper716
    chopper716 Member
    Victorville, CA
    Alright guys, my bike is done minus the wiring and paint. I want to get it running this weekend but I need some major help finding a simple wiring diagram for this thing. All I'm running right now is a headlight, tail light/brake light ignition etc. I know you guys can help me out 8)
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    You R Welcome!
  3. chopper716
    chopper716 Member
    Victorville, CA
    Stupid question
    What do the letters mean? I'm assuming Gr means ground
  4. bill
    bill Active Member
    Raleigh, NC
    Wire colors R/W red with white stripe...
  5. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Chopper GR means green
  6. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    In the Clymer manual, the "L" means blue, don't ask me why.
  7. PaintIt(Flat)Black
    PaintIt(Flat)Black Member
    Sterling, MA
    L stands for Blue because B already stands for Black.
    The Gr could also be Gy either way it is Grey. Green is G.
    Here is a general guide to wire color coding for bikes.
    B=Black (ground)
    Br=Brown
    W=White
    Y=Yellow
    G=Green
    Gy or Gr=Grey
    L=Blue
    O=Orange
    P=Pink
    R=Red
    and some stranger ones
    Dg=Dark Green
    Sb=Light Blue
    Ch=Dark brown
    Also to be noted, anywhere this is a / between two letters it means that its is a (first symbol Color) wire with a (Second symbol color) stripe on it.
  8. chopper716
    chopper716 Member
    Victorville, CA
    Thanks a lot!
  9. chopper716
    chopper716 Member
    Victorville, CA
    What is the ACG and what does it look like?
  10. chacal
    Alternating Current Generator.............it's your alternator!
  11. dwcopple
    bay city, michigan
    in the motor
  12. chacal
    on the left side
  13. chopper716
    chopper716 Member
    Victorville, CA
    I thought that was the pickup coil? But I know what you're talking about, those wires coming out of the left side of the motor.
  14. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    The pick up coil is on the left hand side, right on the end of the crank, the ACG(alternator) is (inside) the round object next to the starter below the carbs.
  15. chopper716
    chopper716 Member
    Victorville, CA
    Thanks guys. I've been working on it all day with that diagram and I'm getting nowhere :lol: :(
    The rectifier has got a green wire coming out of it and I don't know what it goes to. So far I've got the three white wires from the rectifier going to the ACG.
  16. dwcopple
    bay city, michigan
    I really have no idea how to make it any easier for you...we are talking only 8-9 wires total needed so I am not sure why it is so difficult. As far as the green wire, did you follow it to see where it went? does it have an adaptor on the end? A butt connector? Are you sure it is the rectifier you are looking at? The only green wires should go to blinkers or a green/yellow to the brake switch...I have no idea what you are looking at.
  17. chopper716
    chopper716 Member
    Victorville, CA
    I think I got it figured out for the most part, we'll see tomorrow hopefully I'll be able to fire it up.
  18. eflat7
    eflat7 Member
    Ive got mine wired like yours. Tomorrow I will post a rundown.
  19. chopper716
    chopper716 Member
    Victorville, CA
    Spent the majority of both days on it. Got it to turn over this morning but wouldn't fire. Went back and realized I forgot to ground the rectifier and forgot to connect the red (hot) wire from the brainbox to the coils. Then when I did this now it won't turn over at all. :(
    I'm going to bed pretty pissed off tonight.
  20. chopper716
    chopper716 Member
    Victorville, CA
    So I'm 90% sure I have this thing wired correctly.
    And the bike turns over, but I'm not getting any spark. I checked my connections from the TCI box to the ignition coils and it's good, yet no spark. Any ideas?
