1. Dec 26, 2024: XJBikes.com server migration work has been is completed. Thank you for your patience. SnoSheriff
Wiring help?
Discussion in 'XJ Technical Chat' started by myasylum, Jul 16, 2014.
  1. myasylum
    myasylum Member
    Grafton, WI
    Hi,
    I tool off the Atari unit and am going from a left and right to a single dash turn signal. Would I just simply splice the left and right together?
    I also am using a brake master cylinder from a CBR600. It has two wire connections? Is this fluid level wires, or for a brake light?
    Thanks!
  2. BleedingOxide
    BleedingOxide Member
    Brighton UK
    Nah I rekon that will turn on both indicators, very confusing for cagers.
    http://frankjohansson.com/stuff/xj550/X ... agram.html
    take a look at the wiring for the turn switch on this diagram.
    I think if you use the yellow/red wire for your dashboard instead, then you wont affect the actual turn signals, but your indicator light should light up when indicating (it might not "flash" tho, and I'm not convinced that the auto cancelling unit will turn it off.).
    as for the brake master, I would expect it to be brake light.
    The wiring diagram doesn't show fluid levels http://i712.photobucket.com/albums/ww12 ... iagram.jpg
    are they Green with white and Green with yellow?
  3. myasylum
    myasylum Member
    Grafton, WI
    BleedingOxide - That is the best diagram I have ever seen! WOW!
    I have a XJ750 though. Now sure how different that would be.
    Can anyone tell me about that diode block? Can that be removed? Shortened?
    Thanks!
    You can just run both the left and right to a single dash indicator by adding a diode to each positive turn signal lead. The diodes will prevent any crossover voltage from leaking through to the other indicator.
  5. myasylum
    myasylum Member
    Grafton, WI
    Doesn't seem that all warning lights have a ground. Not the typical black wire at least.
  6. k-moe
    If it has two terminals then one will be for power and the other for ground (The terminals are interchangeable on an incandescent lamp. An LED lamp will have the terminals marked). If there is only one terminal then the case serves as ground (this is not a common setup).
    Simply removing the diode block will eliminate all of the safety circuits, and make the bike inoperable. It can be removed, but that requires a lot of time and effort, and you'll have a less-safe vehicle.
  7. myasylum
    myasylum Member
    Grafton, WI
    Maybe I can fit the diode block in the headlight case? The wires are just really long.
    Can anyone tell me if the wire for the oil light would be brown/red?
    Would I then just need a ground wire for the other side?
    I think I almost had er' licked! :)
  8. myasylum
    myasylum Member
    Grafton, WI
  9. peganit2
    peganit2 Member
    Davison Mi
    WOW IS RIGHT!!!!!!! It's interactive!! Who made that diagram?
    Same question for my 81 650
  10. peganit2
    peganit2 Member
    Davison Mi
    I'm gonna make sure alll the electrical components are functioning just because that diagram is so amazing.
  11. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    bigfitz will like this interactive...right up his alley...for a 550.....
    Now where is the one for a Xj750 ?
  12. gomk007
    gomk007 Member
    Minneapolis, MN USA 55406
  13. myasylum
    myasylum Member
    Grafton, WI
    Its great and all that you guys love the diagram, and so do I... but I still have the same questions...
    "Maybe I can fit the diode block in the headlight case? The wires are just really long.
    Would I then just need a ground wire for the other side? "
    Thanks to all!
  14. peganit2
    peganit2 Member
    Davison Mi
    That should be the template for every vehicular wiring diagram ever made.
  15. BleedingOxide
    Brighton UK
    The red/white wire is a live feed from a fuse that goes to the Oil level Light.
    The black/red wire is the negative from the light that goes through the diode block to the oil level switch.
    If theres enough oil, the negative cant ground so the light doesn't come on.
    Dont see any brown/red wires on the diagram, must be PO.
    If it runs to the Diode block (which I hide in my headlight bucket) then its the negative.
  16. myasylum
    myasylum Member
    Grafton, WI
    Ok...
    I have the headlight hooked up according to the diagram, but no power!
    Tail lights work, and brake lights work, but no headlight.
    It should be large green, large yellow, and black.
    Seems simple enough. Can someone help me figure out what might be wrong?
    Thanks!
  17. k-moe
    The headlight won't come on until the engine spins fast enough to start. The headlight relay is under the left side cover, just below the TCI. You can check for power to the relay, and for continuity between the headlight and the relay.
  18. myasylum
    myasylum Member
    Grafton, WI
    Well... that might explain things.
    The tank is getting painted so it won't be running for awhile.
    Their is 4 wires on the relay. I'm not sure which one to check or what it should read, much less the wire to check for continuity.
    I'm not real good at this stuff obviously.
    I'm not so sure I should just assume the headlight will work. It should though.
    Also, the directionals do not flash. They just stay on. I haven't used the diodes yet. Is it safe to assume that is why?
  19. myasylum
    myasylum Member
    Grafton, WI
    Is the gauges and tail lights only go on when the bike is running too? Or just the headlight?
  20. k-moe
    Just the headlight and the auxilary light. The gauge lamps, taillight, and turn indicators will all function before the engine starts.
    The engine does not have to actually run for the headlight circuit to go live, it just needs to spin fast enough. You can spin the engine with the starter and the relay should close if it's working correctly.
    The turn indicators just staying on could be from not using diodes with your single lamp, or it could be due to not having enough current draw on the signal relay. Typically not having the diodes installed will cause both sets of signals to flash.
    Remind me what signal lamps you are using and what relay. Are you sticking with the factory system and just wiring in the new gauges with the single dash indicator?
