wiring lights
Discussion in 'XJ Modifications' started by ayudame, Sep 7, 2010.
  1. ayudame
    ayudame New Member
    new hampshire
    wiring in two headlights. can i use low beam for one and high for both? same with two led strips for tail light/ brake light.
  2. Cmccully04
    Cmccully04 Member
    State College, PA
    Short answere is yes. Long answere I will leave to rick or fitz, im sure they will want to chime in :) with pros and cons
  3. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    If the LED strips are wired for dual intensity, several vendors sell those.
    If single intensity, you would need to be creative to make one dimmer for "tail light".
    Head light - probably but no expert... and you risk overloading existing relays/wires/fuses.
  4. poprider
    poprider Member
    Seattle, WA
    If you don't mind me asking, what colors are the wires for the headlight? I can't find them on my wiring diagram (too fuzzy to make out)
  5. ayudame
    ayudame New Member
    new hampshire
    does the brake light have to be a different intensity or would the additional strip turning on be sufficient to stay legal?
