wiring need help
Discussion in 'XJ Technical Chat' started by bikerpoole1, Apr 6, 2009.
  1. bikerpoole1
    bikerpoole1 New Member
    hi i have a 1983 xj750 only problem is i dont have 1 single wire on bike so i have never heard it running could some one please advise me on what electrical componants i would need to get her running i dont need light just yet just need to start her up so far i have coils regulator starter/solinoid cdi unit am i missing anything thanks
  2. skar80
    skar80 New Member
    there are some relays you will need if you dont need lights yet you will need a side stand relay and a starter relay. When you plug in your tci box make sure you dont plug in the connector for the head light relay (same size as the small one on tci box) or you will fry the tci i found that one out the hard way. Good luck
  3. Robert
    Start combing flea-bay for a replacement harness, 82-83 ought to work for your needs. If all of the relays and ignition components are there, bonus!
