wiring
Discussion in 'XJ Technical Chat' started by twix8949, Aug 18, 2012.
  1. twix8949
    twix8949 New Member
    dalton, GA
    i want to eliminate most of the wiring on my 82 xj750 could someone show me or tell me how? i wan it it to be almost striped thanks :?:
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
  3. twix8949
    twix8949 New Member
    dalton, GA
    thanks
  4. Orange-n-Black
    Memphis Area
    There's no turn signals on that diagram. If that's the way you are planning to go, better check with dmv. Some states require turn signals.
  5. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Ya I have a revised one adding in signal lights and neutral, high beam, and turn signal indicator lights. I just don't have it on hand.
  6. twix8949
    twix8949 New Member
    dalton, GA
    i would rather have every thing maverickbr77 talked about just for legal reasons
  7. maverickbr77
    maverickbr77 Member
    Lowville, New York
    My reworked diagram is in ny on paper and I'm in NH so I can't get to it
    I have 4 leds on my custom dash blue for high beam, green for neutral, and 2 yellow 1 for right and 1 for left signal. refered to as indicator lights below
    neutral indicator is: power (I think I split it off the brake light fuse) - indicator light - neutral switch
    high beam indicator: power (off of the high beam power wire) - indicator light - ground
    signals I put on there own fuse so extend the fuse panel in the diagram to add another fuse I also use a aftermarket electronic flasher that has been moded to keep self cancel and allow me to use led signals but any 2 pin flasher will work for simplification.
    signals: fuse - flasher - signal switch which splits you into right and left
    left side: split to front and back
    back: signal - ground
    front: split to indicator and signal - each go to a ground.
    hope that makes sense
    anthony pover likes this.
  8. twix8949
    twix8949 New Member
    dalton, GA
    yep thanks I'm going to get another wiring harness to start with so i don't screw up the factory one lol
  9. danielcarver47
    danielcarver47 Member
    carolina borders
  10. readlee
    readlee New Member
    Twickenham
    FYI I managed to fit a CF13 3 pin to my xj750. Brown is + and connects to B+ pin, the Brown/White is your BULB side which connects to L pin. Lastly, you need to connect E- to the frame or and earth wire. You can leave the Yellow/Green wire, which is your auto off trigger.
