Won't start checklist
Discussion in 'XJ Technical Chat' started by Grape Ape, Jul 25, 2017.
  1. Grape Ape
    Grape Ape New Member
    Mississauga, Ontario
    So I got the turn signals resolved but the bike won't start. 1985 maxim 750
    So the starter will roll it over no problem. Haven't performed compression check yet but with plugs removed the starter spins significantly faster so there is definitely some compression.
    The ignition coils and plug wires are setup going from the rider position left to right 1-4-2-3 and I have checked and there is spark. I am running NGK DR8EA plugs. That's what I got when I asked for plugs at Canadian tire however they are not always the most reliable for that sort of thing.
    So now getting to the carbs, making sure I have everything connected properly. The fuel line goes to the T between carbs 2 and 3. The T's between 1-2 and 3-4 are overflows only? Vacuum line off #1 boot to fuel petcock.
    I'll hit the starter motor and the engine rolls over and it will sound like it's trying to start by sputtering but it will die if I let off the starter. When I turn the key on next time I'll here a 'puff' from the exhaust which I find a bit odd. The bike has pod filters as the stock air box was not included. I am thinking it is a lack of fuel issue but I have not checked the valve clearances and I don't see any reason to suspect timing issues yet. I am wondering if I have neglected to check anything before I pull off the carbs to have them rebuilt. I am not very familiar carburetor engines.
    Thanks for any help.
    Maxim X 750 or just a Maxim 750?
    edit out wrong info on plugs
    is fuel flowing to carbs from tank?
    battery fully charged and not droping below 9.8 volts when turning over?
  3. Grape Ape
    Battery was fully charged when it got weak jumped it off of my running car. Fuel is flowing to the carb bowls proved through opening bowl drains and draining several litres of fuel out.
    Tomorrow I will get new plugs.
    Not entirely sure what the difference is between maxim x or maxim ownership says x7c not sure how much that helps. Mine is water cooled.
  4. XJ550H
    water cooled is a Maxim X
    your resistor plugs weaken the spark more than normal
    also ohm out your coils primary wires and spark plug wires could be bad spark plug caps or sparkplug wires need to be trimed back a little due to corrision.
    then ohm out pick up coils
  5. XJ550H
    Maxim X uses resistor plugs so you do have the correct ones
    best not to have your car running when you jumpstart bike
    ignition specs link
    iXJ750-X water-cooled models:
    Pick-up coils:
    120 ohms +/- 20% = 96 ohms to 144 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.7 ohms +/- 10% = 2.43 ohms - 2.97 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    12K ohms +/- 20% = 9,600 ohms - 14,400 ohms acceptable range
    Spark plug caps:
    15K +/- 20% = 12,000 to 18,000 ohms per cap acceptable range
    Spark plugs:
    5K ohms per plug
  6. Grape Ape
    I'll bust out the tester tomorrow afternoon. Thanks for the info.
  7. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    Be careful when trimming your wires. Make sure you have enough left to reach your plugs.
  8. mlew
    mlew Well-Known Member
    Apex, NC
    1-4-3-2 ?????????
    If you have factory coils with the factory labels them you have the wires on the wrong cylinders making the firing order wrong.
    One coil feeds cylinder 1 and 4, the other coil does 2 and 3. Rearrange the wires to 1-2-3-4 from left to right.
  9. Timbox
    Timbox Well-Known Member
    ^^^^+1 Make sure the firing order is right or you will have issues.
  10. Grape Ape
    So if I am sitting on the seat looking at the two coils they should go from left to right 1-2 and 3-4?
  11. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    No, the cylinder numbers from left to right are 1-2-3-4. One coil connects to cylinders 1 and 4, the other cylinders 2 and 3
  12. mlew
    Apex, NC
    Sitting on your bike the cylinders are numbered from left to right 1-2-3-4. Re arrange your plug wires to match that.
  13. Grape Ape
    Think there is a misunderstanding here. Currently Left coil is connected to cylinder cylinder 1 and cylinder 4 right coil is connected to cylinder 2 and cylinder 3.
  14. XJ550H
    this is correct
  15. Grape Ape
    Trimmed back spark plug wires, cleaned contacts on the pick up coil and an abusive amount of carbon cleaner. Started up a bit sputtery once it heated up ran well a little hesitant and Smokey. Blew an old hard and crusty coolant hose.
    Thanks for all the help guys. Now gotta track down a few more parts.
