wont start unless prime 1st
Discussion in 'XJ Technical Chat' started by ant797, Apr 7, 2016.
  1. ant797
    ant797 Member
    western australia
    i changed the jets around on my xj750 had them the wrong way round and now it runs great without smoking only thing is if its sitting for a day or 3 it needs to be set to prime to get started is this normal? im guessing the carbies are drying out
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    No, that is not normal, at least not in that short of time. First, check for fuel in the bowls. Sounds like one or more may be leaking down requiring the use of prime.
  3. ant797
    ant797 Member
    western australia
    thanks maybe i got few lose bowl screws maybe hopefuly realy tired of pulling the carbies out
  4. XJ550H
    could be fuel rail o rings, leaky gasket.
  5. ant797
    ant797 Member
    western australia
    i turned it upside down and sucked on the fuel hose to test that the needles where sealing properly there was no leaks there in guesing if the fuel rail had leaks it would suck air
  6. XJ550H
    it only takes a small drip drip drip to drain the carbs you would not necessarily be able to test for that in the way you discribed
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Sounds normal to me. I always prime my bowls (around 30 seconds) prior to a cold start. It usually doesn't take that long for the bowls to fill. My bike has no fuel leaks.
    Gary H.
  8. k-moe
    I only need to use prime after the bike has sat for two weeks or more.
  9. ant797
    ant797 Member
    western australia
    ohwell guess its one of those things might be because the carbies are ultra clean
