Wont start with button
Discussion in 'XJ Technical Chat' started by SLKid, Feb 9, 2010.
  1. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    When i hit the start button the light dims and the oil light clicks on (normal) but no spark.
    When I turn the key i hear one click. I bought a solenoid off ebay that was said to have worked. So, i start the bike with the old solenoid, and its starts are sometimes erratic, so i figured new solenoid time. Remove old solenoid, install used one, and it tries to cough over once. Then nothing ever again from the button. I jumped the solenoid and she starts. Ok, darn i bought a bad solenoid. Install old Solenoid and still nothin... ?? So i replace all the fuses including main just cause and still nothin. Went through the wires near TCI and start button and cleaned them all out. Still nothing..
    So should I just buy one of those farm tractor universal solenoids and try that? Or could it be like a TCI issue?
  2. markie
    markie Member
    Suffolk, England
    This is very similar to a post a couple of weeks ago. Look at the wiring diagram of your manual. You can think of the starting circuit as two actual circuits. A heavy current circuit from the battery, through the solenoid and to the starter motor AND a light current circuit from ignition switch, through any safety or cut out relays and to the control side of the solenoid.
    Is the solenoid coming in every time (Loud click from behind the battery) but the motor does not turn over when you press the starter button? If Yes, then the solenoid (Or possibly starter motor) is at fault. Make sure the battery is fully charged.
    Or, if the solenoid is not energising then it could be the sidestand switch, relay or starter button. Use a tester/meter to find where the voltage is missing. The previous poster found a loose connection.
  3. Stamplicker
    Stamplicker Member
    London Ontario
    Obvious, but maybe it's the start button? or kill switch?
  4. bluewire38
    bluewire38 New Member
    i'm going though the same proplem on my 81 midnite i installed a diffrent switch didn't help i'm thinking a bad ground some where i'll let you know or if you found the proplem let me know
  5. SLKid
    SLKid Active Member
    Well time to unwrap the wires and bust out the Voltmeter. She starts up REAL nice when I jump the solenoid. I jsut bought a universal lawn mower one for it so I know its good. 10 bucks. Hopefully its just a loose connection. I need new controls anyway, but prefer not to be forced to buy em
  6. Lou627
    Lou627 Member
    Queens, NY
    If it starts up fine when jumped, I'm pretty certain it's your solenoid. If it was tci related it wouldn't start or run well. Bad start button or solenoid.
  7. SLKid
    SLKid Active Member
    Start button is fine, I think. Anyone know what each wire is supposed to read out at? Got a brand new solenoid. I think its a relay... How do you ground out the Sidestand relay?? Thats one of the things I havent checked yet.
    I have the start button apart, and I took a little peice of wire and jumped all the connections and still got nothing. So has to be my safety senors somewhere... Hmm
    EDIT: By i get nothing I mean the oil light clicks on like usual but no go on starter
    I hate Wiring troubleshooting... Stuff confuses me sometimes.
    So if I took a piece of wire and put it in the + and - of my relay harness clip thing it'll cancel itself out right? ~sigh~ would just love to hear her start from the button. She sounds fanTASTIC when she's runnin. My winter tune up paid off
    -Chris
  8. markie
    markie Member
    Suffolk, England
    SL, If you can pm me - or post here - a copy of your wiring diagram I might be able to help better.
    Obviously, they made lots of different XJs and they ended up in different countries with different specs. The 700 didn't come to the UK!
    If you are convinced the button is good and so is the solenoid then it's likely to be a bad connection in the loom but you will need the diagram to find it.
  9. SLKid
    SLKid Active Member
    Anyone know how to ground the sidestand relay? I dont really need it
  10. bigfitz52
    You can simply unplug any of the safety relays to effectively bypass them.
  11. parts
    parts Member
    prescott valley az
    Have you taken the switch ass'y apart just to eliminate a short?
    Mine acted similar and it turned out the head light wires shorted.
    The burned wire eventualy affected the start-switch wire.
