Won't Stay Running
Discussion in 'XJ Technical Chat' started by EMS5700, Jun 24, 2019.
  1. EMS5700
    EMS5700 New Member
    Chicago
    Carbs have been cleaned and bench synced, bike will only start and stay running with starting fluid or with my hand on the throttle. If I let it idle it will die immediately it's getting fuel I can see the fuel filter filled with fuel I've messed with the idle screw nothing. I'm at a loss
  2. Toomanybikes
    Tsawwassen bc
    Welcome to the clan.
    There is one item that is overlooked during the cleaning process.
    There’s a small passage in the float bowl that gets gummed up. And if it doesn’t clear easily, then a bit of heat does the trick for me. Fill the hole with carb cleaner and heat the outside of the bowl until it bubbles and repeat until clear .
    Timbox likes this.
  3. Timbox
    Timbox Well-Known Member
    That is the culprit for sure! I use a bread tie, strip it down to the wire and use it to poke open the hole. Carb cleaner and compressed air with the bread tie works very well.
  4. EMS5700
    EMS5700 New Member
    Chicago
    I will give that a shot thank you
  5. XJ550H
    next thing to look at is the pilot jet circuit it runs the bike up until 2 or 3k rpm when the mains kick in
    sand down the red tube on the carb cleaner to fit into that hole. be carful as it is going to spray out the well in the bowl bodt directly above the little hole on the rim of the bowl where the brass tube goes. it should shoot across the room
  6. XJ550H
    going to save those from now on;)
    Timbox likes this.
  7. Jim Steele
    Jim Steele New Member
    USA - Kansas
    Just paid $3.00 for a little brush and lots of little rigid wires. I just started my 82 Seca 750 a few minutes ago (first time in two years) and need the same remedies. Ether and no idle or down throttle. Carbs coming back off again only this bike has the stock air cleaner box.
  8. XJ550H
    notice the smallest size is still not small enough to go down the well and through the jet in the side of the bowl.
    your pilot jets and mixture circuit is what idles the bike after the enrichment circuit starts and warms up the bike.
  9. XJ550H
