Would you run this bore ?
Discussion in 'XJ Technical Chat' started by a100man, May 19, 2014.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    HI All
    Following teh seizure issue described below I pulled the bores and thought they looked Ok however on one I am left with some permanent 'roughness' where some water obviously sat for a while. It's not deep but 320 grit isn't really getting it out and I don't want to go overboard and make the bore oval.
    Would you run 'as is' and accept that there might be a compression issue on that pot. here's the pic..[​IMG]
    Photobox
  2. hogfiddles
    If they don't look good and smooth, with nice cross- hatching, they're not good enough to use, imho
    Dave
  3. k-moe
    That will require a rebore, or a new liner.
  4. jesse8931
    jesse8931 Member
    ann arbor, mi
    Hell no....
  5. bigfitz52
    At the very least.
  6. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    I was always taught as a quick check that if you can catch the edge of a scratch with your thumbnail, it is too deep and needs to be rebored.
  7. a100man
    Bedford, UK
    Come on guys - don't sit on the fence, tell me how it really is.. :wink:
    in fairness the picture makes it look bad but it shouldn't be too big a problem to get
    another set - I hope...
    Cheers
    james
