Wow!! that's loud
Discussion in 'XJ Modifications' started by supernube, Apr 10, 2009.
  1. supernube
    supernube Member
    Ok. I stripped my 82 seca 650 down to the engine and frame. Did a complete rebuild and rewired the electrical for simplicity. Looks awesome, but now when I fire it the engine takes off. Instantly at 5-6 k rpm. The throttle cable is fine (not too tight) and the choke is good too. I'm stumped. Presently pulling the carbs apart since once during the rebuild they took a tumble off the table. Any ideas or advice would be appreciated
  2. redfire
    redfire Member
    Arkadelphia, Arkansas
    perhaps reversed the choke and throttle cables, seems to be a common occurance. do you have your idle thumb screw in too much?
  3. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    Super, make sure when you got the carbs off that they pass the clunk test. You may have a sleeve hanging keeping your revs up.
  4. supernube
    supernube Member
    idle screw is all the way out and i made sure the trottle cable actuated the correct parts. what's the clunk test?
  5. bigfitz52
    Please add your location to your profile (location and climate can affect answers) and some details about your bike, like mileage, to your sig.
    The clunk test is ensuring that all of your carb slides can fall with a resounding "clunk." If not, you gots some polishin' to do.
    There are a number of possible causes for your problem the more information you can provide the better.
  6. supernube
    supernube Member
    passed the clunk test. I'm in portland, or which is why I rewired. the rain here is hell on an old bike's electrics. what else do you need to know. by the way, thanks for the help.
  7. dwcopple
    dwcopple Active Member
    bay city, michigan
    vacuum leak
  8. P2Fabrication
    P2Fabrication Member
    New Jersey
    i second the vacuum leak^ :wink:
