WTB 81 XJ 650 Parts
Discussion in 'For Sale, Trade/Swap, Wanted' started by brianh64, Sep 12, 2008.
  1. brianh64
    brianh64 Member
    Milton, FL
    Does anybody have cylinders and pistons, gas tank emblems & right side battery cover for an 81 XJ 650 they care to part with.
  2. brianh64
    brianh64 Member
    Milton, FL
    Just picked up jug and pistons off ebay today, now I am just looking for tank emblems and right cover.
  3. chacal
    Emblems, in stock! PM me on the right side cover, let me know what color you are looking for.
    Fuel Tank Emblems:
    ed4) OEM and reproduction FUEL TANK EMBLEMS fit on the sides of the tank and spell out the name "YAMAHA" in big letters against a black background. Most emblems used adhesive tape to mount, while all XJ550, XJ650 Maxim and Midnight Maxim, and XJ1100 emblems are retained to the tank via two small screws.
    HCP138 OEM right side FUEL TANK EMBLEM "YAMAHA", black plastic emblem with polished gold raised lettering. Although this emblem is for the right side of the tank, it will also fit the left side also, although you will not be able to get it to lie perfectly flush with the tank surface. For all XJ550 Maxim models. Uses two small screws to mount each emblem.
    $ 27.95
    NOTE: the following XJ650 Maxim tank emblems (HCP140LH and HCP140RH) may be successfully used on all XJ550 Maxim and Seca gas tanks in place of the non-available original emblems for those models. The mounting screw hole locations are exactly the same, and although the front-to-back and top-to-bottom emblem curvature is slightly different between all of the models, it is not enough to be noticeable once in installed.
    XJ550 owners can also apply some double-side tape to the back of the emblems (in addition to using the screw mounts) to get a factory original fit. Alternatively, a slow, gentle application of heat to the XJ650 emblems will make the emblems "bendable" and they can be gently tweaked to a more proper fit on XJ550 model tanks.
    HCP140LH OEM left side FUEL TANK EMBLEM "YAMAHA", black plastic emblem with polished gold raised lettering. For all XJ650 Maxim and Midnight Maxim models. Uses two small screws to mount each emblem.
    $ 29.95
    HCP140RH OEM right side FUEL TANK EMBLEM "YAMAHA", black plastic emblem with polished gold raised lettering. For all XJ650 Maxim and Midnight Maxim models. Uses two small screws to mount each emblem.
    $ 29.95
    HCP2408 OEM left or right side FUEL TANK EMBLEM "YAMAHA", black plastic emblem with polished chrome raised lettering. For all XJ650RJ Seca models. Installs with supplied adhesive tape to mount emblem to the tank.
    $ 39.95
    HCP2414 OEM right side FUEL TANK EMBLEM "YAMAHA", round orange plastic emblem with silvered lettering. Although this emblem is for the right side of the tank, it will also fit the left side also, although you may not be able to get it to lie perfectly flush with the tank surface. For all 1985 XJ700 models. Stick-on designs installs with supplied adhesive tape to mount emblem to the tank..
    $ 49.95
    HCP8216 OEM left side FUEL TANK EMBLEM "YAMAHA", long oval plastic emblem with a polished gold lettering and outer rim and a black lettering background. This emblem is a close (but not perfect) match for the unavailable original emblem, and has the same overall appearance and style, but it is about 10% smaller in overall size than the original. For all 1986 XJ700 models. Uses adhesive tape to mount emblem.
    $ 28.95
    HCP8217 OEM right side FUEL TANK EMBLEM "YAMAHA", long oval plastic emblem with a polished gold lettering and outer rim and a black lettering background. This emblem is a close (but not perfect) match for the unavailable original emblem, and has the same overall appearance and style, but it is about 10% smaller in overall size than the original. For all 1986 XJ700 models. Uses supplied adhesive tape to mount emblem.
    $ 28.95
    HCP8218 OEM left side FUEL TANK EMBLEM "YAMAHA", long oval plastic emblem with a brushed silver lettering and outer rim and a black lettering background. This emblem is a close (but not perfect) match for the unavailable original emblem, and has the same overall appearance and style, but it is about 10% smaller in overall size than the original. For all 1986 XJ700 models. Uses supplied adhesive tape to mount emblem.
    $ 28.95
    HCP8219 OEM right side FUEL TANK EMBLEM "YAMAHA", long oval plastic emblem with a brushed silver lettering and outer rim and a black lettering background. This emblem is a close (but not perfect) match for the unavailable original emblem, and has the same overall appearance and style, but it is about 10% smaller in overall size than the original. For all 1986 XJ700 models. Uses supplied adhesive tape to mount emblem.
    $ 28.95
    HCP145 OEM left side FUEL TANK EMBLEM "YAMAHA", black plastic emblem with polished gold raised lettering. For all XJ750 and XJ900RK models. Uses supplied adhesive tape to mount emblem.
    $ 33.95
    HCP144 OEM right side FUEL TANK EMBLEM "YAMAHA", black plastic emblem with polished gold raised lettering. For all XJ750 and XJ900RK models. Uses supplied adhesive tape to mount emblem.
    $ 33.95
    HCP142 OEM fuel tank emblem MOUNTING SCREW, uses 2 per emblem, for all XJ550 models, and all XJ650 Maxim and XJ650 Midnight Maxim models. Each:
    $ 0.75
