WTB: Misc 82 Xj650 Maxim parts
Discussion in 'For Sale, Trade/Swap, Wanted' started by Toreadorranger, Jan 2, 2009.
  1. Toreadorranger
    Toreadorranger Member
    Salem, CT
    Im rebuilding a parts bike so Im missing alot of little parts.
    Heres the list of things I need.
    Shifter
    Carb to engine boots
    Front axle spacer (inbetween rightside of wheel and fork)
    Gas cap screw
  2. organizedinsanity
    organizedinsanity Member
    Check your pm.
  3. Toreadorranger
    Salem, CT
    I also need the screw that holds the tank lid on.
  4. Toreadorranger
    Salem, CT
    Still need these parts.
  5. schooter
    shoot, there was a kid, tyler soemthing, not too far down in this sell trade etc. forum, that has a whole parts bike, he was trying to get a basket case running, but he couldnt... try pming him, see what happens
  6. rhys
    rhys Member
    Columbia, MO
    Also, that screw is likely a fairly generic fastener. I'll check it out when I get a second. You can probably pick up a replacement for about $0.06 at Ace Westlake.
    That spacer is another story. I have one for my running bike, but I'm missing the one for my parts bike. There's a guy at my office with a miniature mill and lathe. I'm going to see if he'll help me make a few of these, since they seem to be hard to come by.
    Does anyone happen to know if these are steel or aluminum or happen to have the exact measurements? (I'm assuming steel.)
  7. eflat7
    eflat7 Member
    Yeah, you should pm Tyler93. I am about to buy some parts from him. He says he has tons... at least two bikes, of parts.
  8. Toreadorranger
    Salem, CT
    Ive tryed to deal with him but he hasnt responded to me in about a week.
  9. rhys
    rhys Member
    Columbia, MO
    I just checked the screw that holds the gas cap in place. It is indeed a standard size:
    M5 x 0.8 x 1.0
    M5 = 5mm diameter
    0.8 = 0.8 threads per millimeter (or 8 threads per centimeter, if you like)
    1.0 = 1.0 cm in length from the BOTTOM of the head to the end of the screw.
    Mine is a button head screw (round on top, flat underneath) that takes a Philips driver. I would stick with that, unless you find a button or similar cap screw that takes a hex driver. A cap screw - which I usually prefer - might not fit with the gas cap closed.
    And you want a lock washer. A quick look at mine makes me think it needs replacing...
  10. rhys
    rhys Member
    Columbia, MO
    As for the spacer, I'll have to pull apart my front end before too long when I rebuild the forks (and the brakes). When I do that, I can measure the outer diameter and width of the spacer for you, in case you want to try to machine one. The inner diameter should be the same as the OD of the axle, of course, perhaps larger by the merest fraction of an inch.
  11. rider44
    rider44 New Member
    Allenwood PA
    I heard I can modify my the timing by 4 degrees, buy milling out the mounting holes of the timing plate.MORE POWER,FASTER,FASTER FASTER!!!!!!!!...
  12. Toreadorranger
    Salem, CT
    Thanks this helps alot. Ill pick one up tomorrow.
  13. Toreadorranger
    Salem, CT
    right now I have a 3/4" pipe fitting im using as a spacer so I can roll the bike around with out the tire and wheel flopping around. But I defidently need the correct spacer for when this thing gets on the road.
