Wtb xj1100 carbs
Discussion in 'For Sale, Trade/Swap, Wanted' started by Tbar, Dec 6, 2010.
  1. Tbar
    Tbar New Member
    Fort Collins CO
    I need carbs that work. Anyone have a set that they want to part with? I should clarify a set that is in working condition.
  2. mlew
    mlew Well-Known Member
    Apex, NC
    What is wrong with your set? Rebuilding is not hard if you have the place to do it. I have a set but they are in need of a rebuild. I could do it for you if you want.
  3. Tbar
    Tbar New Member
    Fort Collins CO
    A pilot jet has been drilled out and the air gas mixture screw has been drilled into. I will get those out with as little damage as I can. I started to price all the replacement parts I need and it is in the hundreds.
    I should say the carbs have been sitting on the bike in storage for over ten years so everything needs to be rplaced.
    I was hoping to get this bike to run before I invest a lot of money into it. I my thoughts were find a working set of carbs fire this thing up, then stripper down and do it right.
    Any thoughts from anyone on this approach?
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Working carbs are tough to come by. Did you check with our parts guy Len to see if he could save you any money? Or list what you need and some of us could dig for a few used parts .
    MN
  5. mlew
    Apex, NC
    Getting it to run is the first step, it does not need to run well. Just enough to check for engine knocks and to run through the gears. You should be able to get it to start and run with your carbs. I have use carbs with partially drilled jets just for test runs to see if the engine was healthy. After that just replace the items that are bad jike the jets, reuse the old needles and gaskets for a while if funds are tight. A good set of working carbs will set you back a couple hundred.
  6. Tbar
    Tbar New Member
    Fort Collins CO
    Thanks for the input guys. I've been looking around for jets and man is yamaha proud. I'm on bike bandit looking into aftermarket jets at this point, it's the needle valve set that I will have to replace. They are completely shot.
    Any thoughts on where I may find a set?
    I have read here that any push in type for an xs will work. Is there any size differences, or any thing that I need to been looking for concerning these?
    Again thanks for all you input on this. I'm starting to realize just how much I love the fuel injection on my 1300
  7. Jamie
    Jamie Member
    Norman, OK
    Go check out www.sudco.com. They have everything you need or ever wanted to know about Mikuni carbs. Tons of parts and useful information. Good luck
  8. chacal
    We do carry all of the rebuild parts you'll ever need for the XJ1100 carbs!
    XS1100 carbs are the "same but different". I would not recommend trying to swap parts (besides minor hardware items) between the two....
