XJ 1100 carbs opened up today
Discussion in 'XJ Technical Chat' started by MN-Maxims, Apr 1, 2012.
  1. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Went to fire up the bike after a short winter rest.
    It was not running so w ell so I thought to pull the carbs and go through and see what was up.
    Float bowls had what looked like rust in the bottom and the brass jets and emulsion tubes were green? Everything else looked OK
    Not sure why the parts turned green?
    I'm gong to flush the tank before that goes back on. Meanwhile I'll be waiting for some new float bowl gaskets from Len.
    Thoughts?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Mositure in the fuel will make brass turn green.
  3. McGyver
    McGyver New Member
    Agreed. Flush the tank with fresh gas, detailed cleaning of carbs and blow out all ports with compressed air. Mine were plugged with sludge: remnants of the tank liner.
  4. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Next year lay it up with some Sea Foam, it REALLY works!!!
