xj 550 ignition coil on a xj650
Discussion in 'XJ Technical Chat' started by xjwebb, Jun 17, 2014.
  1. xjwebb
    xjwebb Member
    Maine
    Will an ignition coil from an 83 550 work on an 82 maxim 650? The reason I ask is because I lost a coil on my 650 and need a replacement.
  2. SQLGuy
    SQLGuy Well-Known Member
    Easiest thing is to check parts list to see if they are the same P/N.
    I did that for you in this case, using: http://www.ronniesmailorder.com/fiche_s ... mfg=Yamaha
    And, yes, they are the same part numbers, although the original PN's were different. The fact that the new parts are the same makes it pretty likely that the originals would interchange as well.
    1983 550:
    7 IGNITION COIL ASY
    4G0-82310-09-00 (replaces 4G0-82310-61-00) 1 $169.99 $141.09
    8 IGNITION COIL ASY
    4G0-82310-09-00 (replaces 4G0-82320-61-00) 1 $169.99 $141.09
    1982 650:
    22 IGNITION COIL ASY
    4G0-82310-09-00 (replaces 4H7-82310-61-00) 1 $169.99 $141.09
    23 IGNITION COIL ASY
    4G0-82310-09-00 (replaces 4H7-82320-61-00) 1 $169.99 $141.09
  3. xjwebb
    xjwebb Member
    Maine
    I called Yamaha and the cross the part numbers. It will work. Thank you
