XJ 550 Low Fuel Mileage
Discussion in 'XJ Technical Chat' started by robvoi, Jun 3, 2012.
  1. robvoi
    robvoi Member
    Well, my first long trip on my '81 550 Seca, 150 miles; I was worried that I used up 3/4 of a tank for the trip. I in the Pacific Northwest and the trip had 2 mountain passes, the first with an elevation of 3022 feet and the second (45 minutes later) 1105 feet.
    I used 3/4 of fuel, is that level of consumption normal or do I need to adjust something along the line? :?
    Thank you everyone for your feedback
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Sounds pretty good to me, 241km to 3/4 a 550 tank.
    I get 250km to reserve on my 750 Seca.
  3. mlew
    mlew Well-Known Member
    Apex, NC
    What was your MPG for the trip?
  4. maverickbr77
    maverickbr77 Member
    Lowville, New York
    seca is what a 4 gallon tank that would put you in the 50 mpg range which is pretty good
  5. bigfitz52
    Start keeping track of the odo mileage and the amount of gas you put in; two or three fill-ups will give you a good average. See what you're actually getting. My 550 Secas usually get between 50~56mpg; generally right around 52.
  6. robvoi
    robvoi Member
    Mileage 147, 2 mountain passes; average speed up the passes: 63mph; I refilled the tank after 100 miles, tank was half full, end of the trip, tank was about 5/8 full.
    That means around 3.5 gallons for the trip, actually not bad considering going up hill.
    Thank you for all your responses, much appreciated 8)
