XJ 650 1981 Clutch Replacement Questions
Discussion in 'XJ Technical Chat' started by cmdaniels, Jun 11, 2011.
  1. cmdaniels
    cmdaniels Member
    Lynchburg VA
    Hi Guys,
    My clutch is going fast and I need some help. I've searched the site and can't really find anything. Has anyone seen a complete walkthrough for a clutch replacement for an 81 xj650?
    As always, all help is appreciated!!!!
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    The only one that I know of is BigFitz's 550/600 clutch walkthrough.
    The 650 clutch is slightly different because there is no "boss spring" and the 650 has a couple extra plates.
    It's a good place to start reading though.
  3. bigfitz52
    Your 650's clutch also won't have tabs on the plain plates to worry about either but is nearly identical to the one in the article otherwise.
    All of the assembly tips and practices I covered apply; and be sure you replace the springs.
  4. cmdaniels
    cmdaniels Member
    Lynchburg VA
    Hi Guys!
    Thanks Fitz. I finished it up yesterday.Pretty easy, and everything works great!Thanks!!!
