XJ 650 4KO
Discussion in 'XJ Technical Chat' started by chips, Mar 25, 2021.
  1. chips
    chips New Member
    Hello all as XJ 650 4K0
    0riginal down pipes are obselete for ex 4K0 -14611-00 /or 01 FOR USA RJ MODELS EX PIPE 1
    how much difference is there between these pipes and 4H7-14611-00 Maxim pipes which are easier to come by
    Chips ( Steve)
  2. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    What collector box/system are you trying to match the header pipes up to.
    The 4H7 pipes are designed to fit a 2 x 2-1 system and the 4K0 pipes a 4-2 system.
    The OD of the 4H7 pipes at the inlet to the 2 x 2-1 system is greater than that of the 28mm dia. 4K0 pipes to the 4-2 system.
