xj 650 valve adjsting tool
Discussion in 'Hangout Lounge' started by casperdog21, Jan 26, 2013.
  1. casperdog21
    casperdog21 Member
    united kingdom
    I want to adjust the valve shims on my xj650 1981 but reading the forum I require a tool, I cant find one in the uk, could anyone tell my where to get one in the states thank you, and what is the cost
  2. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Casper, you do not havo to have he tool. It may help to hold down the valve shim buckets but this job is totally doable withoutthe tool. Here is a video that helped me through the job:
    http://youtu.be/V3gxT57eoDE
    Good luck
  3. hogfiddles
    the tool is easy to get, but you can search the forums here for the 'Zip Tie Method'. It is a whole lot quicker and easier.
    I have two of the tools, sometimes use them for practice, but decided to try the zip tie method at one point, just so I could prove it was not as effective, and ended up doing the job in less than half the normal time. Plus if you have two people, you can actually do two valves at the same time......
    Dave F
  4. schmuckaholic
    California
    Indeed. The tool didn't work on my 750J, so I *had* to use the zip tie.
  5. Krafty
    Krafty Member
    Point Clark ON
    I use the Electrical wire method, using the solid core wire you can manipulate the end to tuck into the valve seat easily.
  6. hogfiddles
    that works too, just make sure that the wire is softer than the valve or the seat.
    Dave F
  7. casperdog21
    casperdog21 Member
    united kingdom
    thank you all very much for the replies I have watched the video and I will do it that way again thank you all for the help
