XJ 700 Instrument lights and tach out, turn signals don't flash
Discussion in 'XJ Technical Chat' started by smsmith4, Jun 18, 2016.
  1. smsmith4
    smsmith4 New Member
    MN
    I have an 85 MaximX 700 and noticed that the tach wasn't working while riding. Forgot to look into it, but the next time I rode, the neutral light quit working. Shortly after that I realized that my turn signals weren't working. The lights are on, but when I press the signal button nothing happens. Master fuze is good, all fuzes in the instrument panel are good. I can't find any other fuzes (even with maintenance manual), but it seems like it should be a big fuze. Ideas? I have a parts bike to try parts from.
  2. smsmith4
    smsmith4 New Member
    MN
    forgot.... the horn also doesn't work
  3. Jetfixer
    Is your fuse block original? I don't have a wiring diagram for an xj700 . If you have one trace wires from fuse block out . I believe they still used a fuse in headlight bucket and there is a diode block also . ( there is in my 82 xj750 seca) you should use a volt meter and check for voltage at the fuses. I' m sure you might have checked this only trying to help.
    The Maxim-X uses ATC fuses, so fusebox failure is unlikely. Checking for voltage at each circuit is the way to go though.
    Anything with a switch in the circuit should have the switch contacts deoxidized to make sure the current can flow.
    Jetfixer likes this.
  5. smsmith4
    smsmith4 New Member
    MN
    Thanks for the help. I found another post that had the exact same issue and it was a 15A fuze in the instrument panel. Re-checked mine and sure enough, missed one that was blown. But now the problem is that after I replaced it and rode 1/2 mile, it burned through the new one. Came back and replaced it while the bike was still hot and it blew that one instantly as soon as I turned on the key. The neutral light flashed on then off to the sound of the fuze popping. Any ideas where to start looking for this issue?
  6. k-moe
    Follow the wires. One is probably pinched, or rubbed through the insulation causing a short.
  7. Jetfixer
    ^^+1 agree with k moe you have wire picking up a ground some where in your harness.
  8. smsmith4
    smsmith4 New Member
    MN
    I tracked it down to my left side horn. I've checked the wires very carefully around the horn and to the switch. Right now I have just remove the wires from that side horn. The right side horn still works everything else is fine. If I put those wires in to the left side horn and turn on the bike it will instantly blow the 15 amp fuse. The next thing I will probably try is switching the wires from the right horn to the left horn to see if that causes an instant blowout. In which case I guess it would mean there's some problem with the horn itself that's causing a ground or maybe it's locked in the on position mechanically.
  9. Jetfixer
    Sounds like you found it.
