xj 750 front shocks
Discussion in 'XJ Technical Chat' started by jcboyd, Sep 21, 2009.
  1. jcboyd
    jcboyd Member
    Dickinson, Texas
    what is the air pressure on the front sahocks of a 1983 xj 750
  2. NORMFERG
    NORMFERG Member
    Morgans Point Texas
    I believe max is 17psi. Try using bicycle pump. You may lose a little pressure when using a gauge to check.
  3. PipeDreams
    PipeDreams Member
    Columbia, Missouri
    It should be around get-a-manual psi.
    :) Just kidding, kind of. But you should get one. Definitely.
    My manual says 5.7PSI standard, maximum of 36PSI... If I'm reading that right. That seems like a big gap. It also says 5.7-17PSI range. I don't get it, but that's what it says.
    Anyone else?
  4. jcboyd
    jcboyd Member
    Dickinson, Texas
    Thanks for the replies.
    Just bought the bike dont have the manual yet.
    17 psi feels too soft, could I go a little more?
  5. chacal
    No! You risk blowing out the lower tube oil seals, and then you'll have a real mess to deal with........
    Make sure you have enough fork oil (which should be changed if you just bought the bike, unless you know, for sure, that fresh oil is in there).
    Other than that, it may be time to change those 25 year old springs.....
  6. Alive
    Alive Active Member
    Queensland, Australia
    If your forks feel soft at 17PSI then perhaps it's time for an oil change or maybe even a spring replacement.
    Personally I don't put any air in my forks but then I do have new progressive fork springs with a 1 inch preloader and 20w fork oil.
    Do you know the history of the forks, oil and springs?
  7. jcboyd
    jcboyd Member
    Dickinson, Texas
    The guy I bought it from put new seals in it.
    Maybe I need to add oil?
    If so, How do I check it and how much oil, and what kind of oil?
  8. Alive
    Alive Active Member
    This is where a manual comes in handy... I don't have one on hand so cannot answer right now. :)
  9. jcboyd
    jcboyd Member
    Dickinson, Texas
    Thanks.
    I am in the process of getting a manual.
    I have had the bike for 5 days.
    Bike seems to run great.
    Just a soft front end.
  10. Alive
    Alive Active Member
    I suggest you spend a few bucks and replace the springs then.... Made a huge difference to my front end and if the seals have been replaced then you won't need to pull the whole forks apart, just pull the tops off, change the springs and oil... Easy job and well worth it.
  11. jcboyd
    jcboyd Member
    Dickinson, Texas
    Thanks.
    Are the springs avaiable at yamaha dealer or online only.
  12. chacal
    We carry them in stock!
  13. RickCoMatic
    If your Front End is excessively diving-down on you ... adding 17 psi to the Forks isn't going to change anything. It's just going to add a very slight pressure to the top of the Fork Oil, ... keeping the Oil Level "Quiet" instead of splashing around.
    17 PSI (max) ... is less pressure than you apply to a balloon to inflate it.
    It's barely over Atmosphere at Sea Level.
    If you are diving and want to do something about it:
    Replace the Fork Springs if they are over 3 years old.
    Use a Progressively wound Spring.
    Change the Fork Fluid to a heavier viscosity.
    Use Hydraulic Jack Oil if you are a XXL or XXXL Guy.
    Pre-Load the Spring.**
    **Consult the Manufacturer about Max Spring Load to avoid having the Spring coils crash together.
  14. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    im new to the biking world and i have a 85 xj700 maxim. how do i know if i need to change the springs. i weight about 170 lbs.
    i guess what im asking is, how much dive should there be or how soft should it feel ?
    thanks
  15. jcboyd
    jcboyd Member
    Dickinson, Texas
    Thanks Guys.
    New springs and oil I will get.
    I am a small guy.
    5' 4" 165 lbs
    How much oil?
    Have manual on the way.
  16. jcboyd
    jcboyd Member
    Dickinson, Texas
    I dont know about dive, but I know there should be a little firmness involved.
    My front end will bottom out and get shakes.
    I can sit on my bike and the front forks sink down significantly.
  17. Alive
    Alive Active Member
    JC.... Talk to Chacal about to cost of replacement springs.... His prices are not the cheapest in the market but you will not beat his fantastic, fast, friendly service.
  18. jcboyd
    jcboyd Member
    Dickinson, Texas
    how do I get hold of him?
  19. Alive
    Alive Active Member
    Go to the bottom of his last post in this thread and click on the PM icon at the bottom of his post
  20. jcboyd
    jcboyd Member
    Dickinson, Texas
    thanks.
    youve been a big help.
    chat at ya later
