XJ Oil Coolers
Discussion in 'XJ Modifications' started by singingotter, Jan 17, 2006.
  1. singingotter
    singingotter Member
    NW Ohio
    I bought a complete setup from a 1985 FZ600 that for the most part, the expensive parts are there. The top oil tubes to the cooler are offset and won't work, and the bottom tubes that wrap around the front engine mount are way to short. So I broke the fittings apart with some heat, and bought some 5/16" brake line to make the new lines with.
    My question is - does anyone have any close-ups of how the bottom tubes are bent around the front engine mount? I'm gonna start with some soft copper tubing to get an idea of how they will wrap around, but pictures would be extremely helpful.
    Thanks!
    Michael
  2. woot
    woot Active Member
    I think that some of the larger maxim's had an oil cooler - I think what they had was a baseplate that went between the oil filter and the bottom end. The pipes from these appear to elbow off and go straight up following the line of the frame tube.
    I'd be temped to use hydralic hose with a nice steel braided finish. A lot easier to get them where you want them.
    Sorry I can't offer you any other help than that.
  3. Hired_Goon
    Hired_Goon Member
    Oz
    My XJ550 has a genuine yamaha oil cooler on it and as woot suggests it goes into each side of the base plate on the oil filter. It has a special angled bracket/tube for the hose.
    If your bike doesn't have the holes on the side then you may have to change over the base plate. The fittings would be hard to fabricate. I can take some pics of mine tonight if you need to see the setup.
    I also have a spare base plate if you want measurements to see if it will fit your engine.
    My clymer manual has a section in the back and lists oil coolers as a yammy performance enhancement so I think it comes as a kit. Eg base plate cooler and pipes. I think it is mainly a Seca option.
    Cheers
    HG
  4. singingotter
    singingotter Member
    NW Ohio
    The distributor plate is the piece that fits between the engine and the oil filter. The oil cooler bolts onto the two threaded holes just below the triple. The hoses and tubing are custom made for each bike. The hose is braided. The metal tubing is on each of the two ends since the bends are severe, and the angle to both the distributor and the oil cooler are sharp in order to avoid the exhaust. I will have no problem bending the tubing and brazing the fittings. What I'm after is how the tubing leaves the distributor plate and avoids the front engine mount, whether the metal tubing passes in front or behind it. That's why a picture would be helpful as I would like it to be as close to OEM as possible.
    Thanks guys.
  5. chevy45412001
    chevy45412001 Member
    illinois
    i'll send pics in the morning. i have the complete set up off the bike and a dig cam,it just a bit late right now and my wife just had open heart surgery today so it may take a day or so too.
  6. Mr.Fork
    Mr.Fork Member
    Calgary, Alberta
    BTW - the guy who makes the XJ Tool (Mike O.) also makes a spin-on oil adaptor that is for oil coolers. It might help you out.
  7. woot
    woot Active Member
    chevy45412001 - A big get well soon - it certainly is an unnerving operation and we wish her a speedy recovery.
  8. Hired_Goon
    Hired_Goon Member
    Oz
    Think this is the pic you are looking for.
  9. singingotter
    singingotter Member
    NW Ohio
    Yes, that is close to what I am looking for. I'm looking for a picture a few inches up from that where the big round tube that goes form one side of the frame to the other that the engine lugs are bolted through. Maybe a perpendicular shot towards the front of the engine in this area. I do appreciate your help :D
    I have viewed a lot of pictures such as yours, but none show how it passes either in front, or behind the front engine mount - that big round bar that goes form one side of the frame to the other that the engine lugs are bolted through. It is located behind the exhaust pipes. The way the Yamaha Parts manual shows the bottom tubing, it looks like it has to pass around the engine mount, between the engine mount and the exhaust headers.
    I'll post some pictures of the areas I'm looking for from my bike. When this thread is finished I'll forward all photos & discussion to Photo Gallery and to the folks who make the XJCD's if no one objects. The XJCD is a good place to store this kind of info and well worth the $10 US.
  10. Hired_Goon
    Hired_Goon Member
    Oz
    Ok, I did take a pic of that last night, but I am at work now so will post a pic later.
    Basically the two pipes come together and are attached to the front of that engine mount by a bracket.
    Hard to get a good pic on my bike as I have a 4 to 1 exhaust and it covers most of the filter area.
  11. singingotter
    singingotter Member
    NW Ohio
    I hope your wife is feeling better and I thank you for your help. Sitting at a hospital bedside takes a lot out of you.
    Yeah, the 4-into-1 exhaust presents a whole new issue. Fun changing your oil filter isn't it?
    Below is the view I am looking for. It will show me how the tubing that leaves the distributor passes in front/behind the front engine mount.
    Here is another showing how little room there is between the engine case and the front engine mount.
    Thanks again everyone.
  12. Hired_Goon
    Hired_Goon Member
    Oz
    Ok, My 550 frame is different than your 650? I just had a look at my bike and I don't have a crosspeice that close to the filter.
    4 to 1 makes it hard but these pics should show the difference.
  13. singingotter
    singingotter Member
    NW Ohio
    I agree. Your frame is definitely different. It is the cross-piece that is giving me the grief. On ebay pictures I had seen in the past for an XJ650 cooler setup, the bottom metal tubing was quite a piece of work. I'm pretty sure that it comes forward from the distributor and wraps around the cross-piece and then runs parallel to the engine case just behind the exhaust.
  14. singingotter
    singingotter Member
    NW Ohio
    Alrighty then, so what do you do in NW Ohio when the sun is shining and it is not 20 degF? You fire up the woodburner in the workshop, take the cover off the XJ, and work all day to get your oil cooler lines brazed up! All finished with the layout work. Now I just need to buy some new hose and black hose clamps, and prime and paint the oil lines. Below are some pics of the finished product.
    This picture is of the oil cooler and the hose guide:
    This picture is of the middle where I installed the Jagg oil cooler bypass valve. I will only use this when it gets over 90 degF.
    This picture is of how I ran the tubing around the front engine mount. Believe it or not, the tubing is 3/4" from the engine mount, and the tubing length is around 5".
    Hope this helps somebody out there. It can be done non-OEM.
  15. woot
    woot Active Member
    Very nice job!
    Was it not possible to get a thermal oil flow do-hicky? Any problems priming the system?
    Cheers,
    woot.
  16. singingotter
    singingotter Member
    NW Ohio
    I think you are referring to a thermostatic control of some sort. I know that oil coolers with fans have them, but don't know of straight oil cooler setups on these bikes that have them.
    As for priming, follow the standard rule of thumb for cars & motorcycles that have had their oil & oil filter changed; after adding the oil, run for 15 minutes in neutral at idle.
  17. snypr
    snypr New Member
    The way you have done it Otter is the same way the Turbo's stock oil cooler is connected, so all should be fine with yours.
  18. singingotter
    singingotter Member
    NW Ohio
    Thanks snyper!
    That's the confirmation I was looking for. Sooooo...I'm off to the shops for braided oil hose and hopefully some black hose clamps. Otherwise I 'll have to wait until Tuesday for the cycle shop to open. Today it will be up to 40 degF again, so I'll fire her up and ride her to check for leaks. The pressure test held steady for 4 hours at 40PSI so no leaks are expected.
    Since your bike came with a cooler...do you just change out your oil & filter, add new oil, run the bike, shut her down and then top the oil off up to level? I talked to some of my biker buddies and they say run her for 4-5 minutes as that is all that is necessary to fill the cooler & filter cavities.
    Thanks again everyone. :D
  19. singingotter
    singingotter Member
    NW Ohio
    I was able to pick up some Dayco 5/16" braided hose today. The gentleman there was showing me the braided SS setups he was making for some HD's. Man do they look sharp. Unfortunately, my modified setup wouldn't look to good since the fittings took up too much room and the hose would have been so short as to not be very flexible.
    Now all I need is to find a set of 4 black anodized SS hose clamps. My Jagg Bypass valve came with them, but I would like to use the same at the tubing connections. Makes everything virtually invisible everything in black except the bypass valve. :D
  20. singingotter
    singingotter Member
    NW Ohio
    I ended up finding some chrome hose end caps that were perfect! I had seen the expensive chrome billet type, but these are chromed brass and were $5 each. I would have preferred them in matt black, but these will make it look cleaner. If I prefer, I may spray paint them matt black later. I think I'll be able to put everything together tonight and snap some pictures of the finished project.
