xj/xs tank badge
Discussion in 'XJ Technical Chat' started by joejr2, Nov 17, 2015.
  1. joejr2
    Santa Fe,NM
    I have been looking around for a set of gold tank badges for an "82" xj650 maxim project.
    I located a set on Mike's XS site,which were reasonably priced, but are advertised for
    an xs650. the holes are 4" apart,same as the maxim tank and they look like they are
    offset about the same. Are they interchangeable with the gold maxim tank badges ?
    Do any of you guys Know ?
  2. hogfiddles
    All of the XS badges I have seen are a lot thicker, are "boxier"and don't have the the sleek contour to the letters.
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
    The holes don't line up, very close but won't work. I'm in the same boat, would love some new ones and there are nice chrome XS badges for a reasonable price but they don't fit.
  4. joejr2
    Santa Fe,NM
    I wonder if I could tweak the holes a little with a chain saw file and fill the ovaled out gaps with jb weld and touch up with black paint. Are the badges too
    thick to conform to the tank ? If I can save a few bucks on each phase of this build I'll have a few bucks left for the next one. Are they so different that
    anyone would notice ? Excepting ,of course, Hogfiddles, Kmoe, or Chacal ?
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    I never purchased one so I don't know. If you do and it works well, please post up your results. I picked up some decent used ones that need refinishing but am open to options.
  6. XJ550H
    maybe a little heat will help them conform to the tank if needed
    do you have a junk one or piece of one to try to heat?
  7. hogfiddles
    I can tell you what happens with the XJ letters but I can't tell you what happens with XSs letters.... With the XJ letters the webbing between the letters softens faster than the letters do, so the letters bold away from each other but don't curve Unless you try to warm up each individual letter. Even then, they don't curve smoothly to the tank. It's better than nothing, but only from several feet away.
    I Have some XS letters at home, and if I get time in the next couple of days I will try to take a side-by-side picture for comparison
  8. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Makes a guy want to fill the indentations and the brackets with body filler and paint the tank and get some gold colored decals laser cut to replace the old tank badges. Better than nothing if you can't get someone to re-produce them I guess.
  9. hogfiddles
    image.jpg XJ badge on top, XS badge on bottom
  10. jayrodoh
    jayrodoh YimYam
    Cleveland
    Thanks Dave, that really clears it up. That XJ badge is one of the best I've seen too!
  11. joejr2
    Santa Fe,NM
    I found excellent tank badges for around $30.00 from Mike's XS
