XJ/XS400 brake caliper interchangability
Discussion in 'XJ Technical Chat' started by phonex98, Dec 3, 2008.
  1. phonex98
    phonex98 New Member
    Hi all,
    the bleeder screw sheared off while trying to loosen it this weekend, and now im looking for a replacement for the caliper. Can anyone tell me which years and models interchange ? Thanks,
    JR
  2. bigfitz52
    You're going to have to give us a bit more info than that, bud. Year, model? Seca? Max? Have you tried a little heat and a Craftsman screw extractor since the caliper is toast otherwise anyway? You can run your part number in Yamaha's system; I'd do it for you but you didn't give us anything to go on...
  3. phonex98
    phonex98 New Member
    Hey Bigfitz.
    Sorry about the vagueness. The truth is I havent got the papers yet! Long story, but I bought the bike for $100, not running... couldnt find the reg. papers at the time, so i brought her home anyways to start working on her. I suspect its an 83. its 400cc and maxim body style.
    Matches this body style
    I will be drilling out the bolt, but if that fails catastrohpically, Ill be looking on EBAY.
    Also, dont know why I didnt try Yamaha's site... I guess im just used to my GSXR, which has no real (listed) interchangable parts! Thanks!
    edit: Where on the site do i find the fiches or whatever it may be ?
  4. phonex98
    phonex98 New Member
    ALright.. well i found it on bike bandit, which is a brilliant site! It even lists which bikes the part is for...
    CALIPER Fits 8 machines
    1982 Yamaha XJ750J View schematics
    1982 Yamaha XS400J View schematics
    1982 Yamaha XS400RJ_RK View schematics
    1983 Yamaha XJ750K View schematics
    1983 Yamaha XJ750MK View schematics
    1983 Yamaha XS400K View schematics
    1983 Yamaha XS400RJ_RK View schematics
    1984 Yamaha RZ350L View schematics
  5. bigfitz52
    You can use the "real" Yamaha site but the diagrams are sometimes hard to read. I use these guys: http://www.babbittsonline.com/pages/par ... fault.aspx plus they're right here in Michigan so I order OE stuff from them occasionally too. Use the section on the left to pull up the fiche for your bike; copy/paste the part number into the section on the right ("quick part lookup") and you'll get a list of everything Yamaha says it fits. You can click on the little "pic" icon and it takes you right to that page in that fiche.
  6. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Hey phonex,
    the 82/83 maxims are the same really, just different numbers on the frame/engine...
    12R for the 83 and 15G for the 82
    Keep us up on your progress, they are fun bikes...
  7. phonex98
    phonex98 New Member
    ZaGhost,
    what you just told me helps alot! The VIN is 9 digits starting with 12R... I spent about an hour trying to look it up, but any VIN lookups require the standard 12 digits... thanks, will keep you updated!
  8. ZaGhost
    ZaGhost Member
    Cool, 83 ... XS400K , same as mine :)
    For pics/info on my rebuild, click the www button under my sig...
