XJ400 1982
Discussion in 'Hangout Lounge' started by imradon, Feb 5, 2017.
  1. imradon
    imradon New Member
    Norway
    Hey looking into buying a new bike. Not the most tech savy person, is this a bike that needs lots of work, it has gone 78000 km. Is that far for this bike?
    Attaching some pictures aswell
  2. imradon
    imradon New Member
    Norway
    If i did anything wrong, or put this the wrong place please tell me.
  3. TheCrazyGnat
    Central PA
    You haven't done anything wrong. One of the things about these bikes that I appreciate is that they aren't horribly complicated. Even I have been able to work my way around them with virtually no electronic experience.
    Depending on how much the previous owner followed recommended service guidelines, it might not need a ton of work, our it could be a significant time and money investment. If you aren't familiar with older bikes, it might be a good idea to take an acquaintance that is along with you. I don't know that the xj400 made it to north America in any numbers, so I haven't seen much about them. Regardless, the xj is a great platform, and if you're willing to learn, a great bike to ride and wrench on.
  4. Simmy
    That bike looks well cared for.
    Although it's mileage is higher than ideal if it's been properly maintained should be good for a few more
  5. k-moe
    It's not a high mileage bike at all. Given the age of the machine it's a sign that it was ridden (and maybe even cared for) instead of sitting in a garage to rot.
  6. hogfiddles
    There was a discussion on this model not too long ago...... basically, it's an xj400 maxim engine in an xj550 seca frame and the 550 seca parts----- kind of like the 900rk/750rl idea but with a 400/550r thing going on instead.
    I believe it was a Japanese-market-only bike
  7. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    Pretty good looking bike, from what I can tell in the pic. As far as being tech savy, these have got to be the least complicated bikes to work on. The biggest issue I have found with them is getting the time to do the work.
  8. imradon
    imradon New Member
    Norway
    Thanks for the replys will be going to look at it on wednesday, and if it runs and everything looks fine i will most likely buy it. Anything special i should look out for?
  9. hogfiddles
    If it looks good but doesn't run, id still buy it for its rarity
  10. k-moe
    Hodaka Combat Wombat. Easier. Only one of everything :)
  11. imradon
    imradon New Member
    Norway
    Everything looked really good about the bike, all the needs to be done is change tired and replace the rubber thingy between the carb and the engine. If anyone know whats the name of that, an point me in a direction to find it, that would be nice.
  12. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Carb holders/intake boots. They seem to have many names depending who you ask.
  13. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    It's a doohickey! Not sure how you'd go about finding parts for a Japan only model. Perhaps eBay Japan? Translation is a bit dicey, so shop carefully. Xs400 parts are completely different from your xj's
  14. XJ550H
    only manual i found looks like this, I think it is an owners manual
    imradon and Stumplifter like this.
  15. gav xj400 4bp h
    gav xj400 4bp h New Member
    uk
    eBay seems to have a lot of used but in good condition parts for sale atm. An at quite reasonable prices as i own a xj400 divvy 4bp1 an needed some parts an they had them an were good on delivery. To I've still got the number for the company i got the parts from if you want it pm me ...... Thanks Gav
  16. cgutz
    cgutz Well-Known Member
    SE South Dakota
    The rubber thingy between engine and carbs may be able to be sealed with RTV if the cracks are not to bad. I did it on my XJ550 and it works fine (doesn't look as pretty as new...someday I will get the new parts from XJ4ever).
    Search RTV fix intake boots motorcycle for lots of information on resealing the boots.
