xj550 fork seals from ebay.
Discussion in 'XJ Technical Chat' started by Grahamdermagraphica, Jun 27, 2014.
  1. Grahamdermagraphica
    Grahamdermagraphica New Member
    Herefordshire U.K.
    Watch the thickness of your oil seals when buying from ebay and other non oem vendors.
    On the left, 11mm thick seals. Totally useless as you wont be able to get the wire clips into the seating groove when they are fitted.
    On the right, 8mm thick and 9.5mm in total. Just right.
    Make sure you check the thicknesses as well as the diameter.
    I hope the quality is ok? Only time will tell.
    Unless any other members have tried that make?
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Only one way to a slove that problem.
    Don't play around with getting parts for a couple bucks less.
    XJ4Ever.
  3. Kickaha
    New Zealand
    Fork seals are one item I always buy genuine, some of the suspension guys hate aftermarket seals as they cause more stiction than OE
