XJ550 Front Brake Pad Replacement Issue
Discussion in 'XJ DIY How-To Instructions' started by Michael R, May 28, 2018.
  1. Michael R
    Michael R Member
    Seattle
    I am in the process of refurbishing my front brake caliper. The old pads fell out easily, but I am having a hard time getting the brake pad retaining pin into the the holes of the new pads - specifically the first one on the piston side. They are EBC pads. Seems like I can’t push them down far enough for the pin to easily slip through the pad holes. Is it ok to do a bit of filing on these?
  2. Toomanybikes
    Tsawwassen bc
    Sometimes the paint on new pads make the hole smaller. Yes by all means a small round file to enlarge the hole.
    But double check the pads with original ones to see if there is any glaring difference that will cause the problem.
  3. Michael R
    Michael R Member
    Seattle
    The holes are large enough. They just don’t want to go in deep enough for the pin to engage the holes. I chucked out the old ones a while back.
  4. XJ550H
    the holes for a set of 550 brake pads need to be opened/ovaled to allow pin to go through.
    you can read about it in the xj4ever catalog. unless you got oem pads
    3 xj550s 3 sets of pads needing enlargment
    HCP1705 Aftermarket standard organic front DISC BRAKE PADS SET, enough to do one front caliper. No wear-limit groove. NOTE: pad retaining pin hole may need a slight amount of filing or reaming for a perfect fit. Fits all XJ550 models, 1981-83 XJ750 Seca, XJ750 Euro, models, XJ1100 front calipers, and 1981 XS1100 Midnight Special front calipers. Each set:
    jayrodoh likes this.
  5. Michael R
    Michael R Member
    Seattle
    That explains it. Filed it out a bit and fits!
