XJ550 Front Brake Piston Removal
Discussion in 'XJ Technical Chat' started by Michael R, May 2, 2018.
  1. Michael R
    Michael R Member
    Seattle
    Is there a different solution for removing a caliper piston if you don’t have access to compressed air?
  2. Michael R
    Michael R Member
    Seattle
    Nevermind! Found the grease gun method thred
  3. a100man
    a100man Well-Known Member
    Bedford, UK
    Messy - but it does work. You can also buy special removal pliers that grip the inside of the piston - never tried them though.
  4. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    You could just pump it out using the fluid that's in the reservoir. If it's free from the brake hose just connect and bleed it up to pump it out also.
  5. Michael R
    Michael R Member
    Seattle
    True, but I have the whole system apart for a reguild.
  6. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    I bought a set of piston removal pliers and found them to be more or less useless. Grease gun method worked really well for me.
  7. FJ111200
    Even the rear brake? Tell me to shut up!
  8. Michael R
    Michael R Member
    Seattle
    Rear is drum. Done.
