XJ550 Headlight Only Turn On When Running?
Discussion in 'XJ Technical Chat' started by Brodie, Mar 19, 2010.
  1. Brodie
    Brodie Member
    Hey guys,
    I been working on my XJ550, I currently have the carbs off to rejet them and I got to dinking around with relocating the fuse box and some other stuff. When I went to test that everything works after relocating it, the headlight doesn't turn on when I turn the ignition on. I can't remember if it turns on when the ignition is on, or if the bike has to be started. Anyone care to enlighten me?
  2. BlackMax
    BlackMax Member
    Brampton Ontario
    The engine has to be running,I think its to save the battery.
  3. SilverSeca
    SilverSeca Member
    Lancaster PA, USA
    Yes, mine come on when the engine is running. Display panel, tail and license plate do light up w just ingnition on.
  4. Brodie
    Brodie Member
    Awesome, thanks for the quick replys guys. I thought for sure I messed something up or blew my headlight out.
  5. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Hmmmm here's a question, Is this done with a realy?
    In my 400, headlight comes on as you turn the key.
    I'd like to reserve the extra current for starting.
    Methinks I need a peek at the 550 wiring diagram :)
  6. TIMEtoRIDE
    A special relay with a "latch" I think a diode or something.
    If you have a really good battery, it can come on with just cranking.
    Once energised the "latch" keeps it "ON" even if you stall.
  7. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I'd like to get one of those for my other bike to keep the headlight off until it's running. I know the starter switch on my Honda disconnects the headlight when you press the starter switch, but it would be nice to not have it come on until the engine fires. That way I can turn the switch on while working on it without so much strain on the battery. Looks like a pretty easy mod to do.
  8. bigfitz52
    It's done with the headlight relay.
    PM me with an email address and you've got one.
  9. PainterD
    How much $$ for one? Is it something I can find at Radio Shack or an auto parts store maybe? I might be interested.
