Xj550 indicator
Discussion in 'XJ Technical Chat' started by Craig middlemore, Nov 16, 2018.
  1. Craig middlemore
    Craig middlemore Member
    Warrington england
    So when I indicate left everything is fine but when I indicate right the back light stays on no flash just on and nothing on the front right . The bulb looks fine is there anything else to loom for or just replace the bulb and bobs your uncle
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Make sure there are two 27 watt bulbs, not a lower (23?) watt bulb - the lower watt bulb caused it to just stay on without flashing.
    Low battery can also cause this.
  3. Craig middlemore
    Warrington england
    It was a flat battery sorted now thank you cgutz
