XJ550 Maxim Caliper Rebuild
Discussion in 'XJ Technical Chat' started by j_ham, Jun 22, 2023.
  1. j_ham
    j_ham Member
    DFW, Texas
    Hey, y'all. Just a quick questions on brake caliper rebuilds:
    Does the flat side of the piston or the "cup" side of the piston go against the pads? When I pulled it apart, the flat side was against the pads and the cup side was in the caliper. The piston on just about every other caliper I've seen has the cup side interfacing with the pads, so I'm thinking somebody has rebuilt this before me and put it in backwards. Is that a correct assumption?
  2. Dan Gardner
    Minneapolis, MN
    If I am reading correctly, the piston was installed incorrectly.
    Installed backwards would require a lot of brake fluid to fill up.
    Roast644 likes this.
  3. Dan Gardner
    Minneapolis, MN
    Here is a random image I found showing proper installation of the piston:
  4. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Maybe the piston had corroded around the seal area and they flipped it as a last ditch band-aid ? I've seen stranger stuff. Probably have done stranger stuff myself...:p
  5. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Your car brake pistons also install open side to pad.
  6. j_ham
    j_ham Member
    DFW, Texas
    Thanks everybody. Looking at Dan’s picture, somebody definitely had swapped it around at some point. Whether on accident or for a reason, I’m not sure. I’ll install it correctly this time.
  7. j_ham
    j_ham Member
    DFW, Texas
    Thinking about it, you’d probably have a tough time bleeding all of the air out of the brakes with it installed backwards. Gives a lot of extra space for an air bubble to get stuck.
  8. Dan Gardner
    Minneapolis, MN
    Yes!
