XJ550 Maxim Fork Rebuild
Discussion in 'XJ Technical Chat' started by jmcgee14, Apr 5, 2013.
  1. jmcgee14
    jmcgee14 New Member
    Massachusetts
    Hello all,
    My question involves taking apart the front forks of my 1981 XJ 550
    I have tried to find the thread on here that explains how to make a tool that allows you to hold the inner dampening rod while you screw and unscrew the Allen bolt at the end of the slider case...so obviously that is where I am at -
    I vaguely remember a DIY tool that involved using a spark plug socket backwards?
    I have followed my Clymer manual to the T up to the point of removing this Allen bolt before pulling out the innards of the fork tube - and the bolt is just spinning along with the inner rod - oddly my manual does not list a tool or technique on how to confront this -
    As always I really appreciate any and all help!!
  2. jmcgee14
    jmcgee14 New Member
    Massachusetts
  3. Special_edy
    Special_edy Member
    Arlington, Texas
    Use a piece of dowel rod, a broom stick or whatever else you can find that will fit down there.
    The fork tube is holding it 90% still, you just have to provide another 10% of force to keep it from turning.
  4. bigfitz52
  5. xjdaver
    xjdaver Member
    Medford, Wisconsin
    This is what I used for my Concours.
    [​IMG][/img]
  6. jmcgee14
    jmcgee14 New Member
    Massachusetts
    Thanks everyone for all the great advice!!!
    I got one out so far with my own variation of the tool shown above - the next should be cake!
    Although I have hit a snag with the lower fork slider oil seals - they seem to be stuck in there pretty good and are ripping out leaving chunks of rubber stuck in the seal grooves
    anyone had this issue??
  7. zombiehouse
    zombiehouse Member
    Pomona, Ca
    I used a broom handle down the tube. To get the oil seal out I used a seal removal tool I got for removing the tailshaft seal on a transmission.
