XJ550 Maxim Fork Rebuild
Discussion in 'XJ Technical Chat' started by jmcgee14, Apr 14, 2013.
  1. jmcgee14
    jmcgee14 New Member
    Massachusetts
    Hi all -
    I have run into a snag trying to replace the lower fork slider case oil seals
    It seems they have somehow welded themselves in there pretty good, probably have not ever been changed - I have a dremel handy but I am not sure if it would be safe to use in this area - or what attachment to use
    So far I have just been trying to scrape out the rubber with a small semi dull screw driver
    just wondering if anyone else has had this trouble and what is the best course to take?
    Thanks!!
  2. moellear
    moellear Member
    Lima, Ohio
    You're not the only one. I just changed mine several weeks ago and struggled as well. After beating them with a screwdriver they were damaged but I was able to get a slip-joint plier in there to grab 'em and pull out. Installing the new ones weren't much easier but at least pounding it in with a rubber mallet and socket of same width, was easier than pulling it out... gawd that sounds dirty... :p :p
