XJ550 Maxim won't shift gears
Discussion in 'XJ Technical Chat' started by Iamwayno, Jun 19, 2015.
  1. Iamwayno
    Iamwayno Member
    MI
    So out of nowhere, I get on my bike this morning to go to work and i get a block down the road and i realize my bike won't shift past 2nd gear! It even feels a little different shifting into neutral. I try to shift up and it feels like the shifting lever is stuck and just won't go any further up.
    Any idea what this may be?
    1981 maxim 550
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    You may have a broken spring in shifter drum.
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    What kind of miles on your XJ? If it is getting high, a broken chain guide could have sent a chunk of plastic down there, preventing you from shifting. My brain is suffering from "Friday Night Fuzzies" and i cant remember techincal terms now. There's a thingie behind a thingie that you can look in to check for chunks of black plastic in. Hopefully somebody who's enjoyed less beer will chime in and actually help here... sorry.
  4. chacal
    INTERNAL SHIFTER MECHANISM PARTS:
    Inside your shifter case side cover are a variety of levers and linkages that translate the motion of the your shifter foot pedal into movements that operate the SHIFTER DRUM, which in turn operates the SHIFTER FORKS which then engage or disengage the various TRANSMISSION DRIVE GEARS. Worn or damaged RETURN SPRINGS can prevent the shifter from operating properly, and are the first thing to check if your bike will not go into gear, is "stuck" in a particular gear, or if you cannot "find neutral".
    Of course, there may other issues which could cause the same problems, particularly the dreaded "disintegrating primary chain guide" issue, but it's always best to determine whether a simple problem exists first..........
    Pictures of the inside of the shifter assembly can be seen at:
    http://xjbikes.com/forums/index.php?threads/20246
    and
    http://xjbikes.com/forums/index.php?threads/28233
    A good write-up on the typical problems and issues involved with these parts can be accessed at:
    http://xjbikes.com/forums/index.php?threads/19227
    http://xjbikes.com/forums/index.php?threads/48591
    However, please note that the exploded diagram attachment on the 19227 page is "typical" for most XJ-series bikes, the actual mechanisms will differ slightly between different models (the diagram shown in the 3rd post is correct for the XJ650 - XJ900 models; most other models use a variation on the same theme).
    NOTE: if this describes your situation:
    Couldn't get her out of (whichever gear you were in when the problem occurred).
    This situation can be caused wither by a broken TENSION SPRING (the small linear-acting spring) or by the TORSION SPRING (the one with one straight arm and one "hooked" arm). Both of these springs are designed to keep the pawl arm properly engaged with the shifter drum "star wheel" segment. Note there is also a long SCREW which retains this star wheel to the shifter drum; if that screw is loose, it will allow the star wheel to rock back and forth or not even engage with the drum, also resulting in the same type of issue.
    On early XJ650 engines and XJ750 Seca engines, the original torsion spring used was somewhat weak, and was replaced by an upgraded spring on later model engines, which also required a slightly different spring collar (sleeve) to be fitted.
    "Today, after a downshift, the shift pedal would not pop back up automatically."
    This problem tends to be caused by a broken TORSION SPRING (the one with straight arms on both ends of the spring) which is supposed to center the selector shaft segment. The earlier 1980-81 XJ650 and XJ750 Seca models were especially susceptible to this problem, and an upgraded, thicker spring (which required a thinner spacer collar underneath) was introduced to the 1982-later models.
    Xjrider92117 likes this.
  5. hogfiddles
    or your chain guide is breaking up
  6. MattiThundrrr
    Hopefully it's one of Chacal's suggestions... simple problems are good ones.
    PS I vow to not post from the inside of a brown bottle any more. Once the kid is asleep and the wife is on Facebook, the computer is pretty inviting...
  7. hogfiddles
    Yep.... Looking back, you mentioned it, Len echoed it, and I reiterated it.
    Ooooh, I spelled it correctly, too!!! Spellcheck didn't even have to correct it:)
  8. Willis75
    Willis75 New Member
    Rochester, NY
    Are there any other problems it could be? I have a similar issue with my XJ550, the bike won't shift, it feels sort of like something is getting bound up. I pulled the clutch and the shifter shaft/mechanism, all three springs on the shifter mechanism seem to be in good shape. Also with the shifter removed I can easily turn the star wheel to shift the bike into all 6 gears, so there shouldn't be any broken chain guide stuck in the gearbox. The screw holding the star wheel to the shifter drum seems to be tight as well. Any other ideas on what the issue could be?
  9. hogfiddles
    Did you LOOK through the hole to SEE if there's anything in there?
  10. a100man
    a100man Well-Known Member
    Bedford, UK
    Guys, from what I read the 550s don't suffer from teh chain guide disintegration issue - cos it ain't there..
  11. k-moe
    The 550 does have a chain guide. It just so happens that is is a hydraulic chain adjuster with a plastic guide. The 500s have less of a problem because the chain is not slapping against the guide at low RPMs, but the plastic can break down due to age, just like any other plastic can.
  12. Willis75
    Willis75 New Member
    Rochester, NY
    Where would this hole be to look through? The 550 doesn't seem to have the big gaping hole in the casting that the 650's/750's do (shown in the pictures above).
    I appreciate the help guys, thank you
  13. hogfiddles
    Forgot for a moment that you're not on a 650/750/etc...
  14. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    You may have to drop the exhaust and sump to check for plastic bits in the oil pump shroud/screen.
    Gary H.
  15. Willis75
    Willis75 New Member
    Rochester, NY
    Pulled the sump, everything looks really clean. Nothing in the oil pump screen, no plastic sitting in the sump. Looking up into the gear box everything looks surprisingly clean as well. Nothing seems to look out of place...
    I reassembled the shifting mechanism just to double check the issue and its still there. Although I can freely spin the star wheel and engage all 6 gears without it, when using the shifter I can only get into the bottom 4 gears and its extremely tough to shift between the those 4.
    Any other ideas guys?
  16. rocs82650
    Middle Tennessee
    Clutch?
    Gary H.
