XJ550 Petcock Parts Question
Discussion in 'XJ Technical Chat' started by Michael R, Aug 15, 2018.
  1. Michael R
    Michael R Member
    Seattle
    Sorry i don’t have a picture - I am rebuilding an OEM petcock for my Seca. There is a small square gasket for the fuel line banjo that needs replacing but it’s not listed in the parts book, nor is it available in the rebuild kits. Where can I score one?
  2. chacal
    We have them in stock:
    HCP114 Aftermarket petcock fuel outlet cover plate GASKET, die cut reproduction of the original. Fits all original XJ550, FJ600, XJ650 (except Turbo), and all 1981-83 XJ750 petcocks that use a detachable fuel outlet port cover plate. NOTE: any original XJ-series petcock that has a front lower drain screw will not have a bottom fuel outlet plate, and thus will not use this gasket.
    Send us an e-mail for pricing and ordering information: info@xj4ever.com
  3. Michael R
    Michael R Member
    Seattle
    What can I do with a loose petcock filter screen? Is there a glue that will hold up to gas?
    No glue.
    You can either buy a new screen from Chacal, or use a center punch to dimple the inside of the bore that the screen fits into. That will provide a snug fit.
    Rebuilding the Yamaha Vacuum Fuel Valve w/pics
    Jetfixer likes this.
  5. Michael R
    Michael R Member
    Seattle
    It worked. Pure genius. Thank you!
  6. k-moe
    Wasn't' me that thought of it.
  7. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    But you did pass it along. Usually that's just as valuable
