xj550 Seca Minimum Wiring Questions
Discussion in 'XJ Modifications' started by jmcgrew, Jun 2, 2016.
  1. jmcgrew
    jmcgrew Member
    Salt Lake City
    Ok, so I'm trying to finish my first ever bike build and got real excited when I started the project about a year ago. I pulled the wiring harness all out not thinking I would forget a bunch of stuff.
    I've seen the XJ minimum wiring diagram that is floating around here somewhere. My question is; the original wiring loom has tons of wires, The bike was a real poor condition and the PO cut and rigged wires all over. With this diagram can really just run this few wires and leave out all the other stuff?
    What about the clutch hand lever wires and kickstand wires? can i just really not run wires to these items and more.
  2. jmcgrew
    jmcgrew Member
    Salt Lake City
  3. k-moe
    You have two options to avoid dealing with the prior owner's f***ery.
    1. Build you own harness (either using the minimum diagram, which I beleive does work for the 550 (though some wire colors may be different). This option eliminates all of the safety features on the bike.
    2. Buy a good used harness and be riding again in a weekend of work.
  4. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I might have one. I need to double check though. Start a conversation with me if your interested.
  5. jmcgrew
    jmcgrew Member
    Salt Lake City
    When building your own harness, is it recommend to cut the old connectors out of the crap harness or use new connectors for the harness you build and what ever you are connecting to? What type of connectors are recommended for the 2nd option?
  6. k-moe
    When building your own harness you can use whatever connectors you want, unless you are replicating the factory harness, in which case you should use the factory connectors so the original components (realys and such) can be used. Reusing the original connectors is fine if they are serviceable. Replacment factory connectore are avaliable through Chacal, and elsewhere.
    If you buy a good used harness it will already have all of the connectors on it.
  7. Eurotas
    Eurotas Member
    Edmonton
    Use weather-pack connectors, they're a little bulky, but work well. Ive been using them for years. There's a little assembling involved, but super easy.
  8. Eurotas
    Eurotas Member
    Edmonton
    http://www.weatherpack.com
  9. jmcgrew
    jmcgrew Member
    Salt Lake City
    So I did the minimum wiring diagram setup. however I want the lights on my aftermarket speedo to work for oil and neutral. Do I have to wire it through the Diode block from the stock harness? Or can I just skip it. and run the wire from the neutral switch straight to the neutral light?
  10. Eurotas
    Eurotas Member
    Edmonton
    I would've just kept those lights from the speedo just to make it easier. I'd just use the neutral switch for power.
  11. k-moe
    The switch provides the ground-path for the circuit.
  12. jmcgrew
    jmcgrew Member
    Salt Lake City
    Back again. I completed the wiring. Only one issue thus far. My blinkers are not blinking. I installed the Flasher relay and excluded wiring up the yellow/green wire, since i'm not running a flasher cancelling unit. Same thing happens. Lights light up but are not blinking. I'm running LED light front/rear. Any thoughts?
  13. Eurotas
    Eurotas Member
    Edmonton
    Hook up some lights with incandescent bulbs on the front and back and see if you can get it to flash. Led lights use such little current, that flashers don't have the juice to work. If you hook up your old lights and it works, you will have to switch your flasher to a solid state LED flasher. Btw can you put up some pics of your wiring? I've been wanting to run minimum wiring on my harness and I don't want to mess things up. I'd like to convert both harnesses into one, and get rid of all of the useless crap.
  14. saftie
    New York, NY
    What eurotas said.
    Also, if I remember correctly, I saw a similar thing on mine when I accidentally mixed up something with the ground wires.
  15. jmcgrew
    jmcgrew Member
    Salt Lake City
    I'll try to post up some pictures but I'm not sure it will help you. It's cleaner than the stock harness but wires are still everywhere. I ended up completely making my own new harness right on the bike. You can do it pretty cheap, and it will consume about 20 hrs of your time.
    I purchased the following:
    http://www.bcpgarage.com/product/20ft-diy-custom-wiring-harness-kit
    http://www.vintageconnections.com/
    I purchased Professional Kit CK-1 as well as individual matching connectors.
    I replaced all the OEM connectors where they are needed. The crimping tool and connectors is a life saver. Honestly 1 of the best purchase I've made for the bike. It's super clean and is legit, none of those crappy auto-zone connectors. They are the real deal
  16. Eurotas
    Eurotas Member
    Edmonton
    Can I send you my harness lol?
  17. jmcgrew
    jmcgrew Member
    Salt Lake City
    hahaha.. you couldn't pay me enough to do it again.
  18. Eurotas
    Eurotas Member
    Edmonton
    How did figure out all of the grounds? Man there's so many, there's where I think I'd be stumped.
  19. jmcgrew
    jmcgrew Member
    Salt Lake City
  20. Eurotas
    Eurotas Member
    Edmonton
    Is this applicable to XJ 650's?
  21. jayrodoh
    jayrodoh YimYam
    Cleveland
    Yes. If you go Motogadget, reach out to Sybe. He rigged up his 650 Maxim tracker with one.
  22. Eurotas
    Eurotas Member
    Edmonton
    How do I search for a user in here?
  23. saftie
    New York, NY
    To reach out, click on inbox
    Start new conversation
    Start typing the name in participants box and it will auto fill
  24. saftie
    New York, NY
    Click on search, posted by member, type in name to see all of the members threads/posts
    And no idea why my stuff is underlined. Feature is disabled
  25. k-moe
    You clicked the underline button in the editing pane.
  26. XJ550H
    yes
  27. XJ550H
    the oil light has a resistor in the diode block as well as a diode.
    one is used to test the light when you push the starter button the other is for when the oil switch turns on due to low oil. I will post my drawing of it and the flasher system.
    if you are using led in the blinkers you need to buy an led flasher to make them work.
  28. XJ550H
    for the oil circuit use with a rectifier diode from radio shack not the 1n4xxx series but the next wattage up 1n5404 Catalog #: 2761144 and a 8.5ohm resistor
    the 1n4003 will work but I just went with a higher wattage. the diode keeps the starter from coming on when the low oil light comes on due to low oil.
    the resistor will control the brightness of bulb . radioshack has 10 ohm 1 watt resistors Catalog #: 2710151 or you could buy 15 ohm Catalog #: 2711102 and put 2 in parrell to get 7.5 ohms this is based on the standard bulb
  29. saftie
    New York, NY
    That's what I thought too but when I clicked it, it actually double underlined. Underline the underline.
