xj550 valve springs
Discussion in 'XJ Technical Chat' started by darren ditmar, Oct 28, 2015.
  1. darren ditmar
    darren ditmar Member
    eugene oregon
    is there any stiffer valve springs?
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    What kind of seat pressure are you looking for at installed valve height?
  3. XJ550H
    did you measure your spring height to see if they are in spec?
    stiffer springs are not going to open or close valves any quicker the cam does that.
    -2mm is spec for free length of springs
  4. SQLGuy
    SQLGuy Well-Known Member
    The cam opens the valve. The spring closes it. The only exception to this is for Ducatis, with their gear-driven/springless valves.
    Stiffer springs will close the valve quicker, and increase cam chain load, and possibly increase cam lobe wear while decreasing valve clearance check interval.
    If you want to push to a higher red line, stiffer springs and lighter buckets are ways to accomplish this without running afoul of valve float.
  5. darren ditmar
    eugene oregon
    i was just hoping to possiby get them to close a little quicker on the top
