xj550 valves need adjusted?
Discussion in 'XJ Technical Chat' started by pat_in_the_hat, Feb 15, 2022.
  1. pat_in_the_hat
    pat_in_the_hat New Member
    Montana
    it has a new sintered fuel filter. and it has a new petcock. i did the mouth suck test and it was working on the bench. the petcock just doesnt seal when the smallest of crap goes thru it. i think the solution is to get the tank as clean as possible. even tho it looked good to me after the last time i cleaned it. maybe more acid.
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    In that case check the petcock screen in the tank for tears.
    jayrodoh likes this.
  3. pat_in_the_hat
    Montana
    an update:
    cleaned the tank again and put a screen over the petcock intake. has been running great. no fuel leakage, perfect running bike. ive put probably close to a hundred miles on it with no problems.
    until now.
    Now it doesnt want to keep a steady idle. it slowly lowers the idle until it dies (takes about a 30 seconds to go from 1100 rpm to dead). runs great until its at a stop. ive increased the idle screw, but thats just making the rpms hang up when coming off the throttle. plus, i dont think it should be that since it was running perfect a few days before.
    any suggestions? clogged fuel filter? loose petcock vacuum tube? plan on taking a deeper look when im off work
