xj550 Windshield
Discussion in 'XJ Technical Chat' started by Jack Miller, Sep 12, 2017.
  1. Jack Miller
    Jack Miller Member
    Northern Illinois
    Does anyone know why the windshield for the XJ650G/H wouldn't work on a XJ550H? From the attached picture the mounting point looks the same, but I don't have a a 650 to compare with. The brackets mount to the front handle bar clamp bolts.
    there is a reason why after 1981 Yamaha stopped putting them wind screens and farings on the 550 seca.
    causes instability.
    correction RH and RJ had cowlings
  3. Jack Miller
    Jack Miller Member
    Northern Illinois
    So what you're saying is that basically the rounded shape of the windshield caused the wind to push side to side and not just push straight back?
  4. XJ550H
    650 4-3/4 inch outside if riser to out side or riser, handle bars 7 " before upsweep curve
    xj 550 6" upsweep
  5. dkavanagh
    Rochester, NY
    I've driven mine with and without. Overall, I find I get less wind in the chest with it on and find that more comfortable. Also, they did put the front cowl on the '82 Seca 550s.
    http://www.yamahapartshouse.com/oemparts/a/yam/500421b8f8700209bc78737f/fairing-cowling
    But, that does explain why I see some red ones with and some without (granted, lots of them get taken off).
  6. XJ550H
    yes at higher speeds what ever that is you start to get a wobble going but that also included the faring
    also see spacing I posted above
    check spacing on 550 if it is same should fit except for the angle I see the mounts are on the risers
    650 risers are flat
  7. XJ550H
    you are correct checked my parts book RH andRJ had cowlings
  8. cgutz
    cgutz Well-Known Member
    SE South Dakota
    That explain
    That explains why over the years a lot of people have asked me if my aftermarket windshield causes instability.
    In fact, mine never has. It is similar in style to Slipstreamer Turbo Fairing. The lower mounts attach to the headlight bucket side bolts, the risers to the handlebars.
    Stumplifter likes this.
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Do you have a steering dampener on there? I believe that yamaha added this to the later faired bikes to counter the headshake from wind acting on the bars. Either that or it was a popular aftermarket option, I can't remember for certain.
  10. dkavanagh
    Rochester, NY
    I wonder if I just haven't gone fast enough to feel this? Must be higher than 85MPH,
  11. cgutz
    SE South Dakota
    No dampener. In its youth, I've had it up to max speed with the windshield on. Our speed limit is 80mph and it cruises fine, even though I rarely exceed 65mph for sustained driving.
  12. XJ550H
    the big problem he will have is the risers (handle bar clamps) are angled may be a good thing may not
  13. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    Mine doesn't get wobbly until I'm doing 160. Without the windscreen I can only do 120 before I feel like the wind is going to push me off the bike.
    I'll probably live longer without the windscreen.
    XJ550H likes this.
  14. Jack Miller
    Jack Miller Member
    Northern Illinois
    My solution was to use the XJ550 mounting brackets which attach to the top pinch bolt on the forks and a NOS Virago Mini III windshield with some extra holes drilled in it. It helps with the wind in the chest a bit, but obviously not a perfect solution. I have the rounded XJ650 Mini Cruiser windshield if anyone has a use for it. $20 plus shipping or pick up locally. The windshield is in excellent condition.
  15. Baker6x6
    Baker6x6 Member
    Winston Salem, NC
    My bike (XJ750) came with an OEM Fairing and had the steering dampener. I never could tell if it really did any good... as i never had the wobble. When I switched the fairing to the "parts bike" for testing (sans dampener)... It had a wobble above 67 mph. I had read alot about the bicycle style neck/stem bearings... for other bikes (my VTX 1300R).. So, I ordered a set of All Balls Tapered Roller stem bearings, and installed them about 4 years ago. I now have no wobble at all, even up to 91 mph, which is how fast my GPS said was my top speed during my trip to the Vintage Yamaha Rally last weekend.
