XJ600 51J Camshaft bearing cap
Discussion in 'XJ Technical Chat' started by Fredrik Svensson, May 4, 2021.
  1. Fredrik Svensson
    Fredrik Svensson New Member
    sweded
    Hi,
    I have a broken bearing cap and wonder if it can replaced with another cap or if it is fitted to the cam? When looking at it there is about 2 mm tolerance towards the cam and I think it can be replaced without problems.
    Image attached.
    Br Fredrik
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    Hi Fredrik
    If I recall one or two of the caps are not bearings at all - just there to hold on the cam cover. Your broken one looks like one of those. So yes replace..
    Cheers
    Franz likes this.
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    yep , exactly as a100man says, its just a receiver for the cover bolt, looks like the cover bolt was tightened too much, they are only 7nm torque.
    i think they are the no3 cap, you need to replace it with the same one
