xj600 chain ?
Discussion in 'XJ Technical Chat' started by madbones, May 10, 2015.
  1. madbones
    madbones New Member
    australia
    Ok so im looking at replacing a chain on my xj600 84' . Now reading the links ive got this
    ( GXW50 RK2535 ). So am i right in thinking its a 535 chain. Ive searched and searched and do you think i can find one. The sprockets are fine so im hoping to just replace the chain. Can i ask the difference in a 535 if thats what im looking at and a 530. Is it just that the width of the links are slightly narrower. Is there any chance of getting away with a 530?.
    Please enlighten me.
    500 series chain: 5/8" pitch (distance between pins)
    Roller diameter: .400" all 500 sizes
    Width between inner plates--
    520: 1/4"
    525: 5/16"
    530: 3/8"
    the numbers after 5 are about width, so it depends on the thickness of your sprockets.
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I have a shaft drive so take my opinion with a grain of salt . . . .
    Given that information; we can surmise that there is a 1/16" difference between a 535 and 530 chain.
    To me that sounds like a giant difference for what I would reference as a 'critical' component.
    I recommend you stay with a 535 - chances are really good if you click on the link in the upper right hand corner for XJ4Ever that he will have the correct chain for you.
  4. XJ550H
    why do you think it is a 535 I find no listings for that as a size.
  5. k-moe
    Start a conversation with user Chacal. He has the correct chain in stock, and sprockets. The spockets may look fine, but they have worn and will do a job on the new chain if you leave them on.
  6. madbones
    madbones New Member
    australia
    Thank you all for your replies. It is appreciated.
    So are the numbers on the chain that i have
    GXW50 RK2535 ) was i right in thinking it is a 535or am i wrong.
    A picture ...........a work in progress. This is an older picture and a lot more has been finished. If i get around to it i will upload a more recent picture.
    Stumplifter likes this.
  7. madbones
    madbones New Member
    australia
    Well i have contacted Len and he has advised me that the numbers do indicate that the chain is in fact a 535. An unusual combination but it could be that they were only fitted to some bikes.
    The most likely option now as suggested is chain and sprockets replacement.
  8. madbones
    madbones New Member
    australia
    A big thank you to Len at xj4ever.
    A very helpful and knowledgeable guy . Parts arrived today and will be fitted up shortly.
    Thank you once again mate!.
  9. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    please post more pictures of your build, we don't get many xj600's on here, let alone modified ones.
    stu
  10. madbones
    madbones New Member
    australia
    Have done Stu.........started a thread in the modifications section. Ill add more pics as i get around to it.
    Cheers mate.
