XJ600 Motor swap into XJ550
Discussion in 'XJ Technical Chat' started by Reed7742, Feb 8, 2016.
  1. Reed7742
    Reed7742 Member
    Mission Ks
    Hey all,
    I recently found a solid 94 XJ600 plant for a pretty decent price. It's currently in a running Seca II. My question is this:
    Is it worth the effort to swap the motors? From what I've read, it should be a fairly direct swap. I can pull the carbs and any other parts from the Seca II. My 550 motor is solid, so this would be a modification for more power, not necessarily because my motor is bad. Any insight would be greatly appreciated.
    Thanks!
    Mmmm 2 bikes is better than 1
  3. Reed7742
    Reed7742 Member
    Mission Ks
    Ha, this is very true.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    I have no experience on this, but I've read a lot of stuff since joining here :)
    I believe you need a pre-Seca II XJ600 motor, the later ones had the cylinders tilted forward and would hit the frame among other things I'm sure.
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1. In addition how much power would you gain for all the work? It would be much different if you wanted to put a 750 mill in your 550.
    Gary H.
  6. Reed7742
    Reed7742 Member
    Mission Ks
    I think you may be right here. I was originally under the assumption that the block was the same and that the motor was just mounted funny. I looked at some pictures and it looks like the actual motor is tilted.
    I saw this post and it looked like a fairly large improvement for (what I thought) was a straight forward swap. It looks like I may be mistaken though.
    As far as swapping in a 750 mill, I wasn't aware that it was possible without a lot of work due to the shaft/chain drive.
  7. rocs82650
    Middle Tennessee
    You are correct.
    Gary H.
  8. XJ550H
    there is a thread posted in the last 6 months about changing the 550 pistons to 600 pistons
  9. a100man
    a100man Well-Known Member
    Bedford, UK
    This ^^ the one your looking at won't fit. Maybe an FJ600 will but you will also need TCI, carbs etc.. and teh carbs (BS32s) will be a tight fit they are physically bigger (not just bore)..
  10. k-moe
    ^^ what they said.
  11. Kickaha
    New Zealand
    That's easy, it's just an overbore, I did it to my one
    I think one of the Cafe racer guys had fitted Seca 2 top end to his 550, so some bits swap over
  12. XJ550H
    what are you looking for in the upgrade?
    red line rpm is what dictates your current top end speed.
    if you are just looking for quicker change the sprockets
  13. Reed7742
    Reed7742 Member
    Mission Ks
    I was just looking for some more power. My bike started out as a Maxim, so it was a little down on power when compared to a Seca. I'm currently running a MAC 4-1 exhaust and K&N pods with a Dynojet stage 3 kit with some tweaks to the pilot jets. It runs really well, but I figured if I could bump up 20 or so HP for less than 400, I'd do it.
  14. XJ550H
  15. k-moe
    Cams + jetting is the only difference between the two XJ550 motors.
    It's not down on power; it's up on torque.
  16. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    If you really want more power, get an 1100. The first time twisting the throttle of an XJ1100 on the freeway is something you will never forget. 95 hp. I rode an XJ650 for 4 years before I bought the 1100. The difference is startling.
    jayrodoh likes this.
  17. XJ550H
    what is ment by this in your signiture line
    XJ550 + 598 motor..
