XJ650 4KO looking for new carb manifold boots
Discussion in 'XJ Technical Chat' started by SqBobSpongePants, May 6, 2025.
  1. SqBobSpongePants
    SqBobSpongePants New Member
    Bodmin Road
    Hi
    I need to replace the cracked carb boots on my 1980 XJ650 4KO.
    I can only find replacements for 1982 onwards.
    See ebay item 322846421296
    Does anyone know if later models are compatible?
    Steve
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    I get a little fuzzy on all the Yamaha model numbers, codes etc. but I believe the 4K0 applies to multiple European bikes 80 - 83 as the frame ID. Assuming you have a 1980 it should be the non Yics motor. I can't find that item number on eBay but many (not all) 82/83 models had Yics engines and those intakes are not compatible.
    If you can swing the extra money, I would highly recommend purchasing the OEM ones. They're available here through Chacal (Len) info@xj4ever.com. He sells both OEM and quality aftermarket ones. I've had a cheap set delaminate internally within a day!! Email him for more info. He has kits too with the bolts and gaskets.
    HCP21225 OEM rubber BARE INTAKE MANIFOLDS SET
    HCP29534 Aftermarket rubber BARE INTAKE MANIFOLDS SET
    If you want to try the eBay route, this is what you'd need:
    https://www.ebay.com/itm/2256357361...RUhM66AooIuDi5jzTIFuiCyLAw==|tkp:BFBM_rzL39Rl
    Here is the info on the bike I believe you have.
    MODEL NAME: XJ650
    STREET NAME: 1980 XJ650
    MODEL ID CODE: 4K0
    FRAME ID: 4K0
    SERIAL NUMBER STARTS AT: 000101
    NOTE: styling and features the same as North American XJ650RJ Seca model, has dual front disc brakes, an oil cooler, and uses the non-YICS 653cc engine.
    SqBobSpongePants likes this.
  3. SqBobSpongePants
    Bodmin Road
    Thanks @jayrodoh.
    This is great info. Hopefully I'll get some time this weekend to go through it.
    I'll let you know how it goes.
