XJ650 and XJ750 wheels.
Discussion in 'XJ Technical Chat' started by SM85, Oct 17, 2020.
  1. SM85
    SM85 Member
    Canada
    Guys, are the rear wheels the same on the XJ650k, and a 1984 Maxim?
    The yahama part#s are different.
    Also, can you change the rear brake drum? If so where can I get the brake drum?
  2. 50gary
    50gary Active Member
    Saginaw, Mi. USA
    What is wrong with your present rear brake drum? The friction surface is cast iron and cast in place, the only way to 'replace'
    the original drum would be to have it spray welded and turned to the proper I. D. I have no idea if the 650 wheel is a direct swap
    with the 84 Maxim. I would just buy a used 650 wheel at a salvage yard, I bought one $25.00 USD.
    Cheers, 50gary
    SM85 likes this.
  3. k-moe
    The drum brake is of a different size. You can swap the wheels, but you'll need the brake plate for the new wheel as well. Just make sure that you're not trying to put a 650 Maxim wheel onto a Maxim-X (watercooled).
    SM85 likes this.
  4. SM85
    SM85 Member
    Canada
    The 1984 750 max has a cracked drum lining, the 1983 650 max has a piece chipped off its lining.
  5. Toomanybikes
    Tsawwassen bc
    Where in Canada are you ?
    I have some wheels Available for your bike
  6. XJ550H
    if you have a 650 get a 750 rim and plate it gives you a brake upgrade.
  7. SM85
    SM85 Member
    Canada
    Crap! Is there any machinist you guys know that will ship me out a couple linings? I can install them myself I say, just remove old lining, and/or press new lining into cavity with green sleeve retainer.
  8. Simmy
    These wheels are cheap and readily available.
    I took 3 fronts and 2 rears and threw them in the metal bin at the land fill because I couldn’t give them away.
    As @50gary stated the going rate is 0-$25, why would you contemplate doing a very difficult and most potentially unsuccessful procedure on a cheapo wheel?
  9. k-moe
    As a hobby machinist I'd love to replace a brake liner on a wheel, but it's not worth the effort when wheels are readily availble. Save your old wheels for when replacements are hard to come by though.
  10. SM85
    SM85 Member
    Canada
    What I am thinking is that I will know what I have.... a used wheel might not have much life either then looking for another and another etc etc.
  11. Simmy
    On a motorcycle capable of 120+ MPH I wouldn’t feel too comfortable with a wheel put together like that. It might be proper tolerances used but maybe not, maybe stressing the hub, who knows. At least with Yamaha I know I can trust them to know what they’re doing.
  12. k-moe
    It is quite rare for a drum to be worn beyond its service life. It is extrordinarly rare to have one that is broken, let alone two. Those wheels were abused.
    You can have a new drum liner fitted to your exising wheels, but since the drums are cracked/chipped you really need to have the wheels evaluated for stress fractures.
    IMO, you're safer getting used wheels.
    Rooster53 and XJ550H like this.
