xj650 exhaust
Discussion in 'XJ Modifications' started by Jim Lahey, Mar 20, 2015.
  1. Jim Lahey
    Jim Lahey Member
    ny
    Hi everyone, I have an 81' xj650 with what looks like stock 4 into 1 rh exhaust.
    I am looking for a replacement muffler/exhaust tip. The one I have has a clamp at inlet and a single bolt tab to frame near exit. The internal baffle has started to rattle some.
    Any suggestions, whereabouts on an exact replacement that others have used.
    Thanks.
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    welcome to the forum. your xj originally had a 4 into 2 exhaust. the 4 into 1 you have now is aftermarket.
    FU
  3. Jim Lahey
    Jim Lahey Member
    ny
    Thanks for input. This is my setup. All I've been able to find is complete 4 into 1 exhaust setups (mac). Header pipe is in good condition, I just need a new muffler/ exhaust tip to match.
  4. Ted
    Ted Member
    Sioux Falls, SD
    You can put just about any muffler or exhaust tip you want on there. Just remove the one that's on there, measure the outside diameter of the header outlet and go shopping!
    Or you could make your own like this guy: http://xjbikes.com/forums/index.php?threads/xj650-mini-muffler-pics.20423/ :D His thread states a 2.5" OD diameter for the header outlet. Pretty good chance yours is the same.
    Dime City Cycles has a pretty nice selection of mufflers at competitive prices.
    http://www.dimecitycycles.com/motor...systems-and-mufflers/motorcycle-mufflers.html
    You might also be able to use a reducer like this if you find a muffler you like that isn't an exact fit for your header:
    http://www.ebay.com/itm/Walker-Exha...Parts_Accessories&hash=item2c905f4dc0&vxp=mtr
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    I like the looks of the 4 into 1, but I don't think you can run a centre stand with them. Does this exhaust increase HP, or is it lighter? My exhaust is rusted, so I'm weighing the options... So many mods, so few dollars!
  6. Orange-n-Black
    Memphis Area
    Most people that have put a 4 into 1 exhaust on their bike, has had to re-jet the carbs. So add that to your list.
  7. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    On a 650 you can indeed run 4-1 with a center stand. Mine came like that, dont know if its a special configuration but it all fits. Side stand too
    Stephen Downey likes this.
  8. Jim Lahey
    Jim Lahey Member
    ny
    My center stand is functional.
  9. hogfiddles
    Stay original..... It looks better, IMNSHO, and no need to tinker with jets
