Xj650 head swap with Yics
Discussion in 'XJ Modifications' started by Danrrhodes, Apr 16, 2025.
  1. Danrrhodes
    Danrrhodes New Member
    Canada
    Hello everyone, I recently bought a 84 xj650 and a 84 xj650 YICS. (Years might be incorrect) The standard 650 had destroyed exhaust studs and holes for them in the block. I took it apon myself to swap the top end of a YICS version, cylinders to valves section of the block. (The YICS had shredded gears) Got the bike running and it seemed to run alright but it sounds like there's a timing issue. Wondering if anyone knows of different timing on the two types of engine
  2. Dan Gardner
    Minneapolis, MN
    So you included the YICS cylinder jugs with the head swap, right?
    I don't think there's any difference in timing - basically the same cams.
  3. Danrrhodes
    Canada
    Yeah basically the whole top end was switched. Are the pistons different? Could that be causing different compression? That shouldn't effect back firing
  4. Dan Gardner
    Minneapolis, MN
    No. Should be same 63mm bore.
    I think it would be really obvious if pistons were wrong size
  5. Franz
    Did you check the valve clearances when you fitted the replacement head and cylinders?
  6. Danrrhodes
    Canada
    I haven't gotten around to it ask I work away from home but, it'll be my next step for sure
  7. Franz
    If you have to change shims do a carburettor sync afterwards.
