xj650 intake manifolds
Discussion in 'XJ Technical Chat' started by RiceBiker, Jan 11, 2016.
  1. RiceBiker
    RiceBiker Member
    San Leandro, CA
    I'm experiencing an erratic idle and I think I'm getting vacuum leaks through the intake manifolds. Intake manifolds are all cracked. I saw a set for an XJ550 available. Will these fit an XJ650?
    1982 XJ650, Maxim,
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    I don't think so.
    Verify there is a leak with an unlit propane torch (w/ gas turned on).
    If idle changes whilst torch is being 'sprayed' around boots then consider doing the bicycle inner tube trick to repair them.
  3. hogfiddles
    not interchangeable
  4. RiceBiker
    RiceBiker Member
    San Leandro, CA
    I'll try it. Has anyone tried liquid electrical tape? Or a combo of inner tube and tape?
  5. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
  6. RiceBiker
    RiceBiker Member
    San Leandro, CA
    I did the liquid tape and it made a dramatic improvement. I'll probably add the inner tube later. It was also way too lean. I had 41's in there and I needed 4-5 turns out on the mixture screws just to idle. I also had no power from idle to about 20 mph (sounded like a Harley) then the power would kick in like a beast. I moved up to 45's with 2.5 turns out. I removed the little brass washers that I used to lift the main jet needles. So I'm back to stock there. Much smoother now.
