Xj650 lack of spark or something else
Discussion in 'XJ Technical Chat' started by memphis, Nov 27, 2015.
  1. memphis
    memphis Member
    Cheltenham/UK
    Hi. I need a help with my bike. I have a xj650 4k0 11N model. I bought this as a non runner/misfire. I took carbs out and overhaul them. Put it on the bike and fired up on cylinder no 4 only. So I started investigation on what's the problem. I took ignition coils out on the table and measure them with multimeter and noticed they have pri resistance of 3.4Ohms and secondary resistance of 14Kohms instead of 2.5 and 11k. I've managed to fire the bike on 1St and 4th cylinder. Then I took the coils out again replaced Ht leads for silicone ones and new spark caps and when trying to fire this thing up it went bang through exhaust and didn't started. bike cranks but struggle to fire up. I've checked resistance on plugs the ignition coils are connected to and one show -5.4ohms and the other one doesn't show anything whichever way I check. I am planning to buy brand new ignition coils but I don't know if the tci is good. Can you advise me what should I checked next please. Also someone replace the fuse box and did a good job
  2. SQLGuy
    SQLGuy Well-Known Member
  3. k-moe
    Swap the coils around so the #1/4 coil is hooked up to #2/4 and vice-versa. Does the problem follow the coil?
  4. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Did you say one coil is connected to #2 and#4?
    If I misread that?
    One coil to #1 &#4 the other to 2&3... I believe....
    If I misunderstood excuse me.
    You may wish to do a compression test and check the valve clearance , since it was bought as a non runner check everything .
    Alan
  5. memphis
    memphis Member
    Cheltenham/UK
    Coil 1-4 works 2-3 doesn't. Compression shows 135 ish PSI on all 4 cylinders. When changing coils around bike doesn't start at all.
  6. k-moe
    When you canged the coils around did you make sure that both the plug wires and the primary wires were switched to the correct cylinder pairs?
    Since you know that 1&4 will fire you should have seen either;
    2&3 fire when the coils were switched, but not 1&2 (bad #2/3 coil)
    1&4 fire but not 2&3 (low or no voltage on the primary feed to 2&3)
    Have you tried starting it in the dark to see if there are any blue sparkies jumping out of the plug wires? That could explain the whole problem (secondary voltage jumping to ground prior to reaching the spark plugs).
  7. SQLGuy
    Mainly, you need to hook up the working coil (1/4), to the unknown (Grey) drive wires and see if you get spark. The bike won't run that way. It's just to check whether the TCI is correctly driving both coils.
  8. XJ550H
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
    Pick-up coils:
    1980-81 XJ650 Maxim and Midnight Maxim: 700 ohms +/- 20% = 560 ohms to 840 ohms acceptable range
    1982 XJ650RJ Seca (non-yics engines): 700 ohms +/- 20% = 560 ohms to 840 ohms acceptable range
    1982-84 XJ650 Maxim: 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    1982 XJ650RJC Seca (yics engine): 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    1982-83 XJ650 Turbo: 120 ohms +/- 20% = 96 ohms to 144 ohms acceptable range
    also make sure your battery is fully charged if it goes below 10 volts tci will not fire.
  9. hogfiddles
    Swap so 1/4 is hooked up to 2/3
    K-moe was up too late
  10. memphis
    memphis Member
    Cheltenham/UK
    Thanks for all your advice. Tomorrow I will try to change coils around
  11. memphis
    memphis Member
    Cheltenham/UK
    Hello again. I've tried today to start the bike and do all the test mentioned above but bike didn't started, now i think that tci is fried, and ignition coils are too strong so i will have to change them for as near as i can get to manufacturer spec. anyone has different ideas ?
  12. hogfiddles
    Why do you think the " tci is fried" and what do you mean by " the coils are too strong"?
  13. memphis
    memphis Member
    Cheltenham/UK
    I've tested the TCI outcome ?
    Battery Ignition OFF - 12.27 V
    Battery Ignition On - 12 V
    TCI red/white cable to red in multimeter black to black Ignition ON 11.5 V
    TCI as above + cranking 7 V
    Coils should be 2.5 Ohm pri resistance and secondary 11 KOhm
    mine are 3.7 Ohm and 14 KOhm previous owner told me they are from kawasaki
  14. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    You're chasing a ghost. 30 year old electricals need to be cleaned and sorted by process of elimination then reset to stock configuration (if possible).Once power through the harness is verified power into and through components will be much easier to troubleshoot. I'm going to shut up now.
    Gary H.
  15. hogfiddles
    Get the right coils to begin with.....
  16. memphis
    memphis Member
    Cheltenham/UK
    Local Yamaha guys told me that original coils are discontinued and their mechanic went through books to find out from what other model I can still buy them and they will be within parameters the original ones should be.
    Price for 2 brand new coils was £160 that's about $240
    I don't mind to spend that much money IF it will work.
    I will order them and see what happens next.
    I want to ask also If I will fit new coils and TCI will not going to work can anything else damage the coils in any way ?
  17. XJ550H
    if you think your tci is bad you could possibly ask here and someone may be w
    correct coils needed
    the 7 volts is a problem. under 10 volts and the tci will not fire.
    try charging the battery or a new battery
  18. rocs82650
    Middle Tennessee
    +1. Have you tried member Chacal? He might be able to send you a good used set for less $.
    Gary H.
  19. memphis
    memphis Member
    Cheltenham/UK
    I'll get new battery and coils and if this will not going to work I will change Tci and pickup coil. thanks for all your help
  20. memphis
    memphis Member
    Cheltenham/UK
    Will try him. I can get here (UK) used coils for about $76 BUT breakers don't give warranty on this and when I've asked them to check resistance on them they told me that they've been taken of running bike.
  21. memphis
    memphis Member
    Cheltenham/UK
    Update on situation. New battery fitted and still doesn't run. On the plug from tci red/white and black cables shows 7V when cranking. When I tool spark plug out and checked the spark it did appear, very weak and not in the rod but went inside the spark plug. Any ideas?
  22. hogfiddles
    What is the voltage at the battery when your cranking it?
  23. Alan63
    Be
    better battery or boost from a good one,
    7volts while cranking is low,
    May need some contacts cleaned as well.
  24. Alan63
    Use logical steps, always begin at the battery, then move forward
    XJ550H likes this.
  25. hogfiddles
    So you got 7 V on these wires… But what are you getting AT THE BATTERY TERMINALS When you crank the engine?
  26. memphis
    memphis Member
    Cheltenham/UK
    I will have a look on Friday what am I getting on the battery when cranking. Thanks for all your help
  27. memphis
    memphis Member
    Cheltenham/UK
    Ok update on situation folks. I've checked voltage when cranking on battery and it drops from 12.5 to 10V
  28. XJ550H
    just bring a meter with you and check them before you buy them
  29. XJ550H
    you need to charge the battery you are at the threshold of tci not firing because of low voltage
  30. memphis
    memphis Member
    Cheltenham/UK
    Hello everyone. I've manage to fire up the bike. on 2 cylinders and sometimes on 1 . I've checked voltage when cranking on the tci and it shows 7 V when engine is running it shows 14V at 2000 rpm . I've checked pickup coils and one shows 635 ohm and other 653 ohm and that is within 20% limit. When I've swooped ignition coils from 1-4 to 2-3 and then started the bike it run again on cylinder 1-4 so I suspect TCI is the problem but then I've stopped the engine and try to started it again and it did a big BANG from the exhaust.
  31. k-moe
    Check the stator output voltage first. It may just be that the alternatior isn't making enough of the magic pixies.
    the backfiring after switching the ignition off and then on is normal. It's a function of how the TCI manages the coils.
  32. memphis
    memphis Member
    Cheltenham/UK
    At 2000 rpm alternator gives about 13.3 volt. Above 2000 rpm goes upto 14
    XJ550H likes this.
  33. XJ550H
    for your referance
    tested my 550 tci is .37 volt lower than battery at standing voltage and drops to 7.8 volts when starting. battery at standing 11.86 drops to 10.75 tci standing 11.49 drops to7.8
  34. memphis
    memphis Member
    Cheltenham/UK
    Hi again. I've got the original ignition coils. Engine fired up, it run rough as hell but rouns on all 4 cylinders. Carbs have been rebuild but not set, and that's why it smoke I hope. I can't think that piston rings are crap because bike has 135psi on all 4 cylinders.
  35. SQLGuy
    Could have leaking valve stem seals, or gas in the oil... but carbs needing cleaning and tuning is a more likely cause at this point. Glad to hear you got the ignition problem solved.
  36. memphis
    memphis Member
    Cheltenham/UK
    I would like to say Thank you to everyone that give me advice about my bike. Not sure if I cured it with different coils but it did work. I will test ride the bike tomorrow and let you all know with results. Carbs have been cleaned but not set. So I will buy kit to set the carbs. I will seek a thread here about it.
  37. Alan63
    Ex
    excellent , if the smoke clears up when the engine warms up I would suspect valve stem seals to be the reason , and IMHO isn't really anything to worry about , that bit of oil on start up is good for the rings and cylinders, and would only use a quart about every 4000-5000 miles
  38. memphis
    memphis Member
    Cheltenham/UK
    Hello again. I've fixed the spark problem. ignition coils was the issue. Replaced for second hand ones just to try if this is the case.
  39. memphis
    memphis Member
    Cheltenham/UK
    Thank you all for your help.
