Xj650 Maxim I think speedo reading is wrong! Please help!
Discussion in 'XJ Technical Chat' started by m4dh4tt3r, Jul 27, 2014.
  1. m4dh4tt3r
    m4dh4tt3r New Member
    Cornwall, UK
    I have recently purchased an XJ650 Maxim and after a 90 mile round trip I'm sure the speedo is wrong. According to the speedo I was doing 65mph for about 30 miles but seemed more like 75 - 80mph! Redv counter @ 65mph was @ 6,000 rpm. It has the original clocks.
    Can anyone help? Does this sound correct :?
  2. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    Depends on maintenance, brake condition, tires, wheel bearings...might be close...
  3. peganit2
    peganit2 Member
    Davison Mi
    Re: Xj650 Maxim I think speedo reading is wrong! Please help
    Nope, after doing all the calculations looks like you where doing 103.1 MPH. 8O
  4. m4dh4tt3r
    Cornwall, UK
    Tyres almost new, bearings just been done, brakes good, recent pads, overall condition is pretty good.
  5. m4dh4tt3r
    Cornwall, UK
    Didn't feel like that fast! I'd say about 85 - 90 max! Hop so anyway or I'm going to get into some real trouble if I'm not careful!
  6. peganit2
    peganit2 Member
    Davison Mi
    Go with the flow.
  7. foks
    foks Member
    the NL
    I guess the speedo might want some lubrication (don't use wd40!)
    My '81 xj650 maxim does about 5000 rpm at 65 mph
  8. swearinhagen
    swearinhagen New Member
    Florida
    I was having a similar problem with my speedometer although mine is off of a different bike. I sprayed some wd40 into it from the back to break corrosion up then sprayed yamalube aerosol silicone to really get it slick.
    That was a couple hundred miles ago and the speedometer is both accurate and smooth.
  9. bigfitz52
  10. waldreps
    waldreps Active Member
    Henning, MN
    I got pulled over by a State Trooper the other day for going too fast. He just gave me a warning and helped me figure out how much my speedo was off. At 65mph my speedo shows 60. I cleaned and lubed the cable after that but I'm not sure it helped or not. I'm not sure I want to dig into the actual gauges. Seems pretty delicate and easy to mess something up.
  11. hogfiddles
    What was the speed limit?
  12. waldreps
    Henning, MN
    The speed limit was 65mph and I had my speedometer on 70mph. He stopped me because he said he clocked me at 77mph. After checking my license, he allowed me to follow him while he held his speed at 65mph which showed as 60mph on my speedometer.
  13. m4dh4tt3r
    Cornwall, UK
    Well I've just been out with my iPhone strapped to the bars using Speedview app.
    The 65mph that I thought I was doing (although it did feel a bit fast), was actually 80mph, and when I was travelling at the speed limit of 70mph I was actually doing just below 90mph! That will explain the feeling faster than my clock was showing!
    So at 30 clock reads 25, 70 clock reads 57! Well at the moment anyway.
    Thanks to everyone for advice, I'll try to sort them out, or look for alternative clocks!
  14. hogfiddles
    How reliable is THAT app? There's no reviews on it--
  15. m4dh4tt3r
    Cornwall, UK
    I downloaded the free one and checked it this morning in work van, if you keep a steady speed, ie 30mph, 60mph etc it's accurate within about 1mph, but then a lot of vehicle clocks have that sort of inaccuracy so I'd say pretty good.
  16. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    "The 65mph that I thought I was doing (although it did feel a bit fast), was actually 80mph, and when I was travelling at the speed limit of 70mph I was actually doing just below 90mph! That will explain the feeling faster than my clock was showing!"
    It is good to know how quick you are moving but it is also important to know how fast (or slow) the traffic around you was going.
    IF you are slow you are a hazard.
    IF you are faster - well I guess you know where you are going and how to get there!
